First, press the door class to go up. Then remove the inner door wall by unscrewing the door handle and other screws you can find. Put a flat screwdriver around the door Wall to lever out the plastic fittings. Pull the door wall down and you now can see the door handle from the inside where you will find two screws that hold the handle. Unscrew the handle from the inside of the door from the two screws and remove the handle from its fitting and then replace the new handle.
Many times the handle is slid on from one side or the other onto the screws. Try sliding the handle off by gently putting a screwdriver or putty knofe under the handle on the side that is still attached and pushing the handle sideways. This should remove the handle so you can remove the mounting screw and get it back on the door. then you can slide the door handle back on after getting the screw attached on the door again.
inside door panel has to come off, then there are usually 1 rod on the handle pull, and one rod on the lock.. these pop off the rod and stay on the hanldle body. there should be @ 3 or 4 nuts on the back side of the handle. thease removed and the old handle shouold pop out.. dont force it... new handle in... .hand snug the nuts, put op rods back in proper holes, snap in clips... TEST BEFORE YOU PUT THE DOOR PANEL BACK ON...... saves lots of time if you happen to put the rods in wrong.
hi, you have to take the door panel off the inside of the door and then their will be two bolts holding the handle from inside the door their will also be metal pins tha run through the handle these need to be put back on properly else the door wont open
Step1:
First, unscrew the 7 screws holding on the door panel
Step2:
Next you carefully pry off the tweeter cover that is where the mirror is.Lift the panel up and off of the door . Undo all of the wiring connections except for the window controller.
Step3:
Open the 2 black rubber view ports (Circled in Yellow) and roll the window up or down until you see the 10mm bolts that hold the window in place.
Step4:
Loosen, but don’t remove these bolts. Slide the window up, and tape it up, or remove the window and set aside. Next, unplug the door lock plug and move the door panel out of the way.Unscrew the gold 10mm bolts that hold on the metal inner door panel . Also remove the Phillips screw that holds the inner door handle on
Step5:
Unscrew the small bolt that holds on the lock cylinder that is behind the quarter-sized black cap on the side of the door. Be careful with that little bolt or it will fall into never land .Pull the lock cylinder out and set aside.
Step6:
Now grasp the door handle, and with your free hand smack your hand holding the handle towards the back of the car. This will release the door handle.Under the door handle is a Phillips screw. Loosen this screw a few turns but don’t remove.
Step7:
Now undo the 3 black star shaped screws on the door lock.You can now wiggle the inside of the door handle until it comes free. See the tabs that hold it onto the door . When you go to put it back on be sure the tabs get back in the right place.Pull the whole inner door panel and lock mechanism free by wiggling it out of where it sits.
Step8:
Now you can undo the 3 cables; 1 from the outer door handle yellow mechanism, 1 from the inner door handle mechanism, and 1 from the inner door lock lever.Put on the new lock and put it all back together.
Be sure to test it as you go. I had to turn the lock cable to the inner door lock lever 180 degrees because it was not unlocking properly when I put it back together the first time.
A couple of other notes, there are 2 pieces of plastic that are for the robots to use when putting the door together for the first time. one is a 3 pronged white plastic thing riveted to the inside of the metal door panel. The other is a white plastic thing covering the lock mechanism. You can cut off the fingers and throw the plastic cover away they are both
useless and in the way.When you put it all back together, just go in the opposite order of disassembly. It is a little tricky to get the yellow plastic outer door handle holder into place. Be sure that the little tabs grab the metal of the door or things will not fit together properly.Be sure to test the power window after you put the window back in place. Do not overtighten the bolts on the window, it is glass…..
There is a wire clip located between the winder handle and the plastic cup/bushing that protects the door panel from the rotational friction of the winder handle. The clip will usually snag and come off if you take a rag and run it around between the winder handle and the plastic cup--kind of like flossing in between teeth. When you are ready to put the handle back on the door, just put the wire clip back into the grooves on the winder handle & simply push the handle back onto the shaft.
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
take door panel off but make sure window is up first. then unclip the rods that are connected to the handle. then unscrew the 2 bolts that are holding the door handle in. then take the handle out and put the new one in and put it back together.
or just go down and get a repair manual at your local auto parts store for less then 20 dollars
