You can, but you need to make the USB stick bootable, which will delete everything on the drive and replace it with the Windows 7 install. You need what's called an ISO of Windows 7, which is basically a fancy word for an image of the install CD.
http://www.techverse.net/how-to-create-a-bootable-usb-pen-drive-for-windows-7/
Nowadays more and more people like to create passwords on Windows 7 PC. In fact, a Windows 7 password is a good way to protect your precious computer data from unauthorized users. Unfortunately, you can be easily locked out of computer as the Windows passwords are easily to be forgotten or lost due to various reasons. In order to regain access to your locked computer and your precious data on it, you need to reset Windows 7 password.
You may forget to create a Windows 7 password reset disk, but resetting Windows 7 password on your own without reinstalling computer is still not a big problem. Just follow the below 4 steps, then you can reset Windows 7 password.
Step 1: Pick one good Windows password recovery tool
To reset Windows 7 password by yourself, you need to use good Window password recovery software. See if the software can reset lost or forgotten Windows password for your Windows 7.Most of the Windows password recovery software available in the market support password recovery for most popular Windows operating systems, like Windows 7/ Vista/XP.
Then, select the appropriate edition of the Windows password recovery tool to reset Windows 7 password. Generally speaking, Windows password recovery tool has 2 or 3 different editions to reset lost Windows password. Take Windows Password Recovery for example, it has 3 editions.
Its Standard edition allows you to burn a bootable CD/DVD to reset lost Windows administrator and user password for Windows 7/Vista/XP/2000/NT while its Professional edition allows you to burn a bootable CD/DVD or USB flash drive to reset Windows local password for Windows 7/Vista/XP/NT/ and Windows Server 2008/2003/2000. And Windows Password Recovery Enterprise enables you to burn a bootable CD/DVD or USB flash drive to reset Windows domain password and Windows local password for all poplar Windows OS.
Step 2: Prepare a PC with driver and a bootable CD/DVD or USB drive
As your PC is locked and you are not able to log on it, you need to find another available computer to download and install the Windows password recovery you choose to burn a bootable CD/DVD or USB flash drive to reset Windows 7 password. Please note the computer should have a driver. Both internal and external driver are Ok. Of course, the device - a bootable CD/DVD or USB flash drive- should also be prepared before starting to reset Windows 7 password.
Step 3: Burn a bootable CD/DVD or USB flash drive to reset Windows 7 password
Once you choose the right recovery tool and the device, you can begin to burn an ISO image file to the device to reset Windows 7 password. Here I take Windows Password Recovery Professional for an example to show you the whole process, which is really simple in fact.
First select to burn an ISO image file to CD/DVD or USB flash drive to reset Windows local password, then click Burn to start burning. Click Ok when the burning task is completed. It is very simple and just takes you a few seconds.
Step 4: Perform Windows 7 password reset with the burned CD/DVD or USB drive
When you have burned a CD/DVD or USB flash drive, you can reset Windows password simply with the burned CD/DVD. Insert the burned CD/DVD or USB flash drive in your locked computer and boot the locked PC from CD/DVD or USB. Then you can reset Windows 7 password under Windows PE. First choose the user name whose password you want to reset and click Reset button, and then click Ok to confirm and continue your operation. Click Ok when the password has been successfully reset.
With this Windows password recovery tool, you can rest lost password on Windows 7 in less than 5 minutes. Forgot Windows 7 password? Just try the steps above to reset Windows 7 password.
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
When you purchase Windows 7 from Microsoft Store, you have the option to download an ISO file or compressed files.
The Windows 7 USB/DVD Download tool allows you to create a copy of your Windows 7 ISO file on a USB flash drive or a DVD.
To create a bootable DVD or USB flash drive, download the ISO file and then run the Windows 7 USB/DVD Download tool.
Once this is done, you can install Windows 7 directly from the USB flash drive or DVD.
Hope it helps
