Try below steps to fix error code 0xc0000005:
1. Locate Google Chrome shortcut on the desktop or in the start menu.
2. Right Click on the shortcut and open Properties.
3. Now go to the Shortcut tab and you'll see a field named Target.
4. Add the following attribute at the end of the Target Field after giving a space: -no-sandbox
5. You are done. Now restart Chrome and you won't see that error message again.
Go to google chrome installation - exe by right click on short cut and choose properties. It would be looking something like this
"c:\Users\...\chrome.exe"
Add the following after this
"c:\Users\...\chrome.exe" --no-sandbox
Save by pressing ok.
Try to open chrome now. It should work.
Unless your OS, security settings or User privileges prohibit or block your software installation, you can try copying the installation files from the CD to your hard drive & run it from that location. If your OS blocks it initially, right click on the installation folder & click 'Properties'. If it's blocked you can either 'Unblock' or 'Allow' it to run & click APPLY before you click OK. Run your installation again & then, you're on your own...haha! Try it, Jack! PS > It's always a good idea to install software after making sure your hard drive's files are compact, not heavily fragmented. This is to minimize glitches or errors that may occur when you use it. (^_')b
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was
installed reversed (180 degrees out of postion). Installing the UFR
Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a
noise and block the Main Thermistor when the shutter should block the
Sub Thermistor. In turn, the shutter will block the Sub Thermistor when
the shutter should block the Main thermistor. This will cause improper
temperature for the Upper Fuser roller and cause the error code.
suggested to go in service mode and reset the error, and see if it will
solve the problem. If the problem presist, a code will appear and that
will be the one we should work on. So we did clear the error, and the
machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Can you provide further details on your problem? Some common reasons on why you get the error code Oxc0000005
are low memory problems and a virus.
-Make sure your computer has enough memory on the system and is not maxing out. -Run anti virus / malware scanners to make sure your system is free of infection.
