Posted on Jan 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minolta 7228 moved from one location to another now copies not clean.
Pull and pushing glass cleaning knob and corona cleaning knob. I am tech savvy. Strong electronic backround.
Rey Bazan
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Apr 03, 2015
Rey Bazan
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
11476
Points
19
I doubt that moving the machine has caused the problem shown.
Regardless- the copier drum is not being cleaned.
I would begin by replacing the Drum Blade.
It is technical and will require your knowledge of the service manual procedure.
Good luck
Adorjani Laszlo
Level 3:
  • Konica Minolta Master 1,316 Answers
  • Posted on Apr 06, 2015
Adorjani Laszlo
Level 3:
Answers
1316
Questions
Helped
457303
Points
2563
Replace the drum and the drum cleaning blades(two),and inspect rhe fusing unit upper fuser roller and the fuser roller oil WEB.
Model 600. Why is it dropping toner near transfer corona unit?
When is the last time the developer and drum where replaced? When the last time was a PM done? Very 250,000 copies a PM must be done? Which replaces the Corona Wires, Developer, Drum, Corona Grid, Web roller for fuser (Hot Part). Also during the PM the Tech should clean the toner out of the Waste Toner collection unit on the image unit. also clean the area around the drum and developer roller.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica 7228 was getting dark copy with streaks.
I would go with the drum and developer also charge wires
How do I clean corona units on Minolta 1081 copier?
Gregory, First remove the drum unit. Then remove the Charge unit. located about the drum on the drum cartridge (Not Inside the Machine) Then remove scortron grid push the front in to release you then have access to the charge wire this model may have the Charge comb type be care the combs are sharp if they are wires be gentle and use a eraser to gentle clean the wires they are very thin. During the copy process the wire/comb applies a HV charge on the drum prior to the image from the mirrors being place on the drum before the paper arrives underneath the drum.
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
3helpful
2answers
How can fix this code C-2105 in konica minolta bizhup 600
C - 2105 Transfer/separation corona cleaning motor home sensor error code.
Remove the transfer/separator corona located in ADU assy,use the vacuum cleaner and clean the corona support and the 2 sensors(located under corona assy rear and front area).After cleaning urn ON the copier and is working.
My minolta ep4000 copy machine print the pages black why?
Clean the optic sisitem componenets,mirrors(4 mirrors),lens,original glass,clean the erase lamp obturation filter(located in OPC drum area,clean the drum charge corona unit(wire,grid).
1helpful
Have a black line on all my scanned files, runs the length of the page, about 1 1/2 inches from the left edge.
To determine if the vertical lines appearing on your printed documents are related to a printing or scanning issue, print a test page by pressing MENU, 4 (Printer), 2 (Print Options), 3(Test Print) and COLOR START.
If the vertical lines appear on the Test Print continue to Procedure A:Cleaning the Corona Wires Inside the Drum.
If the vertical lines do NOT appear on the Test Print continue to Procedure B: Cleaning the Scanner Glass.
Procedure A: Cleaning the Corona Wires Inside the Drum:
NOTE: Brother strongly recommends that customers do not use generic drumunits and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
A1. Power off the Brother machine using the power switch located on the right side of the machine.
A2. Press down on the front cover release lever and open the front coverby pulling it towards you.
A3. Hold the green handle of the drum unit (labeled 1). Lift the drum unit up and then pull it out until it stops.
NOTE: If you cannot pull the drum unit out, make sure that the front cover is fully open.
A4. Remove the toner cartridges one at a time, by holding the handle of the cartridge and lifting it up and out of the drum unit.
Note: We recommend you place the toner cartridge(s) on a clean, flat surface with a piece of disposable paper underneath it in case you accidentally spill or scatter toner.
A5. Lift the white plastic corona wire cover by lifting the tabs locatedon the right and left side of the cover.
A6. Clean the corona wire inside the drum unit by gently sliding the green tab from left to right several times.
Note: Be sure to return the tab to the home position. If you do not, printed pages may have a vertical stripe.
A7. Close the corona wire cover.
A8. Repeat Steps 5 through 7 to clean each of the remaining three coronawires.
A9. Reinstall the toner cartridge(s):
NOTE: Before reinstalling the toner cartridge, shake the toner cartridgeside to side.
Hold the handle of the toner cartridge and slide the toner cartridge into the drum unit. Make sure that you match the toner cartridge color to the same color label on the drum. Fold down the toner cartridge handle once the toner cartridge is in place. Repeat this for all the toner cartridges.
A10. Push the drum unit back into the machine until it clicks into place.
A11. Close the front door and power on the Brother machine.
A12. Print a test page by pressing Menu, 4 (Printer), 2 (Print Options),3(Test Print) and Color Start.
B1. For safety reasons, power the Brother machine Off using the power switch located on the right side of the machine.
B2. Lift the Document Cover and clean the following with a lint-free cloth moistened with a non-flammable glass cleaner:
a. Run your fingertip over the scanner glass of the flat bed to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris. (Caution! Do notpress down on the glass very hard.)
b. Run your fingertip over the scanner glass on the left to check for debris. If you feel debris, clean the entire glass area but concentrating in the area in which you felt the debris.
c. The white plastic pad located on the underside of the Document Cover
d. The white plastic pressure bar located to the left of the white plastic pad.
B3. Close the Document Cover.
B4. Test the machine by making a copy of a blank sheet of paper using the ADF (Automatic Document Feeder) and a copy using the Flat Bed.
a. To make a copy using the ADF, place the document face UP in the ADF, press the COPY mode key located below the LCD display and then COLOR START. If the problem continues,repeat Steps 2b and 2d at least 3 additional times.
b. To make a copy using the flat bed, lift the Document Cover of the flat bed, place the document face down on the scanner glass (make sure the ADF is empty) and close the Document Cover. Press the COPY mode key located below the LCD display and then COLOR START. If the problem continues, repeat Steps 2a and 2c at least 3 additional times.
2helpful
Minolta EP1085 copier - replaced drum but need to make adjustments for auto darkness, etc please help
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
My Kyocera Point Source Ai 2310 make lines on the copies
There is a cleaner for the main corona. It is a small blue knob located above the waste toner tank. Try pulling that in and out a few times to clean the corona wire.
Light copies
The optics need to be cleaned also. If you are tech savvy, then there are two screws that hold down the glass on the right side of the top of the copier. lift up the glass, power must be off. then with a soft cloth, wip the mirrors that you can see. Other wise the corona wires will need to be cleaned in side the copier.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
