Press the y= button on the far left under the screen then type (1/5) then press the X,T,n button then minus 2. Press the GRAPH button on far right under the screen.
I have a TI-83 and there has been a dark spot on my screen for several years and it has not been a problem. Try to use yours for as long as possible unless the screen is unviewable.
The Texas Instruments TI-83 is a graphing calculator. It's aimed towards math and science students and lets them graph and compare functions, perform data plotting and perform analysis. It has an updateable memory for adding software applications. The device comes pre-loaded with applications too. An optional connectivity kit allows you to hook the device up to your computer, and there are also optional slide cases to protect it.
Turn on the TI-83. Press the On button.
Step 2Adjust the display contrast. Press and release the key marked "2nd" and then press and hold the arrow buttons, which are below and above the yellow half-shaded circle.
Step 3Go to the Home Screen. You can do this from anywhere. Just press the button marked 2nd and then Quit.
Step 4Perform a sample calculation to get the hang of how to use the device: Model flipping a coin 10 times. Track how many of those coin flips end up in a heads result and you want to do this simulation ten times. Press Math and the left arrow which will bring up the MATH PRB menu.
Yes you can use it, here is the formula: Y= V(t+ (i/c))^(tc) V=amount put in, t=time, i=intrest rate, c= amount of times it is compounded.
(I know this because I have a TI-83 calculator)
Well it seems that you are graphing stat points and forgot to turn them off. This can be easily fixed by going to 2nd and Stat Plot then make sure all the stat plots are turned off. This should solve your issue.
Are there funny arrows at the left of your Y= screen?
The illustration and solution are courtesy of
Jesse Phillips, who cites
this
page from the Texas Instruments
support site:
In order to select additional graphs, the Transformation Graphing App
will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus
Family. Uninstalling the App does not erase it from the calculator, it
disables it from interfering with the normal graphing modes. Below are
the steps to successfully uninstall the App.
