Usb cable with hdmi input to t.v.
You will not get a HDMI feed through a USB port! What make, model tablet are you trying to connect to the Toshiba 19SL410U LCD TV?
You mentioned a "usb cable" but you cannot connect an external display to a tablet's USB ports. If you are using an HDMI cable, then you will need to select which display is active through the tablet's settings (Android) or control panel (Windows) and also make sure that the TV is set to the appropriate HDMI connection through the input selection.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
