Contact the authorized service center immediately. The set is not perfect in terms of Wi-Fi. http://electronicshelponline.blogspot.com/
SOURCE: philips 55 inch tv weirdness
If it is turning off by itself then your power supply might be going out. If it does not bother you too much right now I would wait until it gets worst. Depending on how much you use it it may not get worst in months.
You can get parts at www.interliquidparts.com
SOURCE: i am unable to connect
Same issue. Samsung 55 inch 8000. Wii component cables plugged in, but it is not recognized.
SOURCE: Hi, I bought a TCL 40" HD TV, the problem is the
I'm sorry for the difficulties you're experiencing in using the Remote with the TV. I was unable to determine whether you're trying to use the supplied Remote with the TV or an Universal Remote.
Please get back to me with these clarifications and I should be able to resolve the issue.
Thanks for understanding.
SOURCE: Can i connect my Sharp flatscreen tv to my wifi
Ron, in order to connect your TV to your home network, it will need an network interface. A network interface can be either a wired network jack on the TV itself, or a built in wireless capability (WiFi). You didn't provide the model number of your particular Sharp TV, so I can't tell you if your TV offers this connectivity or not.
Even if your TV offers wired or wireless connectivity, some TVs only allow network access to update firmware or to display "still" JPEG or GIF images; not to stream audio or video. The TV will need to have some sort of player to display or play video and / or audio files. Even then, if the TV is not fairly new enough, it may lack the support for newer file formats - such as .MKV, MPEG, etc. that are used for a large number of HD content.
You can get around this hurdle by connecting a newer computer to the TV. Purchase a wireless keyboard & mouse and connect the computer's video card to the TV so that it will appear as a monitor to the computer. Make sure your get a video card in the computer that will provide a digital video output - (HDMI, DVI, etc.) and a cable that can plug into one of the unused A/V inputs on the TV. If using a cable other then HDMI, you'll need to provide a cable between the computer's audio output and the TV's audio input. Use the computer's network interface to download or stream a program directly to your 55 inch "monitor".
I hope this helps - good luck!
