Televison & Video Logo
m
mike spatz Posted on Dec 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Viper car alarm lock and unlock works fine but will not let key turn
Will no let key turn
aph1
Level 2:
New Friend:
  • Expert 139 Answers
  • Posted on Dec 12, 2014
aph1
Expert
Level 2:
New Friend:
Answers
139
Questions
0
Helped
42403
Points
290
Spray oil into lock
2 Related Answers
Anonymous
  • Posted on Oct 05, 2008
SOURCE: Viper auto alarm
Check the wiring again, The Ford company uses a light control module in their vehicles. It is fact that the main CPU (Central Processing Unit) stays on line for about 45-60 minutes after the vehicle is shut off that this could show enough of a voltage drop to trigger the alarm when it goes off. If at all possible you may want to monitor the voltage after shutting the truck off and see if the alarm triggers at the same time the voltage drop decreases across the battery after the CPU goes to sleep (45-60 minutes). I hope this helps or at least explains why you may see a foltage draw while testing. Remember to be patient while waiting for the computer to shut down. it will.
Good Luck,
Anonymous
  • 22 Answers
  • Posted on Dec 04, 2008
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
1helpful
Driver door Unlock triggers horn beeping
just unlocking drivers door alarm thinks its been slimmed ---this also works when you use physical key will set alarm off until key into ignition and turn on or use fob to turn off
How do I turn off the alarm?
Try pressing the unlock button twice quickly.
The viper 350 system locks and unlock no chirping sound and the car does not start
when this happens it is because it has a valet function. this function is used to turn off the alarm but the lock and unlock will still work. to reactivate the alarm open the door, turn the key on, then off and then press valet switch once and this will reset the alarm.
2011 nissan sentra s door lock actuator wiring diagram
From the plug in door lock harness of the Viper alarm (green and blue): the green lock wire goes to the red wire of the vehicle in the driver kick panel and the blue wire goes to the pink wire in the kick panel. The light green with black wire from the Viper alarm goes to the white wire in the drivers kick panel. This white wire is the factory alarm disarm wire. It tests with the key in the door cylinder. Turn the key to unlock the door and the wire should register ground.
2helpful
2answers
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
2helpful
My viper 5002 alarm i don't know witch wire's to use off the viper alarm's for the power lock's
The door lock wires for the Viper alarm are green (-)lock and blue (-) unlock. The Viper system only provides a negative lock/unlock pulse for the door locks. So, if you are working on a vehicle that has positive door locks you will have to install relays to change the polarity.
4helpful
2answers
Disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
1helpful
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Top Viper Televison & Video Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
