Error 64 - Lift motor position potentiometer or its cable is faulty
Ooooh, error 64 is not easy. If it was 63 you'd be ok or even 65....not so bad but 64 is a tough one. You may need to re-shuffle the discombobulataory co-functional interpolations by accessing the ancillary positioning extrapolation cog that rotates the comfufulator prior to the sequential disengagement of the photomagraphical fusion vacillator After that it's pretty straightforward apart from the reverse thrust inductors needing a shunt to blow the cobwebs out. If that doesn't work, you could try cutting the power supply off, throwing a dust sheet over it and using it as a hat-stand. Good luck
