I do every thing but not solve this problem
Phone Number
800-474-6836
OR THEY CAN CALL YOU INSTEAD:
http://gethuman.com/call-back/Hewlett-Packard-HP/
OR CALL FREE VIA WEB:
http://zingaya.com/widget/3d4efa4eb13b741a9c661565d567fb11?referrer='+escape(window.location.href)+'&extra=to%3A18004746836%3BtoHash%3A9eb63a6de819ec5144e37092a10f8b6842bc50a4',%20'_blank',%20'width=236,height=220,resizable=no,toolbar=no,menubar=no,location=no,status=no');void(0);
Average Wait: 16 mins - 24 hours, 7 days
Hp printer Offline
SOURCE: HP LaserJet 1320 lights
hi there andy u will find your harraness from u formatter board has beeb broken or one of the plugs arnt making contact on the baord only to solve the problem is to trace everypoint out to find the break and then replace that cable link
SOURCE: error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
SOURCE: My Hp Laser Jet 3390 has a 10.1000 suppy error
If you are technical, remove batery inside and wait for one hour. Put battery back and printer will be ok
SOURCE: error 51.1 HP 4100
Error 51.X is a loss of beam-detect occurred.Possible reasons:
1 - Beam-detect error
2 - Laser error
1. Press GO. The page containing the error will
automatically be reprinted. 2. Turn the printer off and then on. 3.
Reseat cables to the laser/ scanner and engine controller. 4. Replace
the laser/scanner. 5. Replace the DC controller.
SOURCE: how to solve error is doc. feeder jam in hp laser
Hello Anil_ kuma61!
First thing you need to do will be check the correct postioning of the pick up roller on the automatic document feeder, open up the top cover, you will see a grey roller on the middle, this roller shouldnt be touching the cork a the bottom.
After checking on this, we need to reset the sensors on the printer, to do this follow this steps:
1) Turn the printer off
2) Take out all supplies, including toner and paper
3) With the printer off, press the down arrow and the cancel at the same time (keep the depressed)
4) Turn the printer on while holding those keys and wait until you a message on the display "permanent storage init"
5) release the keys and wait to the printer to come back to ready
