Vizio model e280i-B1 smart 28 " hdtv
SOURCE: VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
SOURCE: Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
SOURCE: VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
SOURCE: HLT6176SX/XAA TV ''MAKING DETAILED SETTINGS FOR PICTURE''
Your TV is on display mode!! The problems that you are having I had with my new TV.. Call Samsung or go online to their website and it will tell you exactly how to fix that small problem. As for the blue light, just go to setup and under light effect you will be able to choose when you want the light to come on.. I hope this is helpful...
SOURCE: My Vizio HDTV has green/red snow on dark/white
Usually if the LVDS cable between the main board and the T-CON board is bad, you will loose one of the three color signals, you may have thermal problem with the T-CON board. I would run the TV with the back open to see if it will take longer for the problem to appear, or get a can of freeze spray for electronic troubleshooting and cool down the T-CON board (board is under the metal shield that you will have to remove to get to all the cables, I would remove the shield and put the screws back in to keep the T-CON board in place).
The TV as shown in my album has bad T-CON board, the pictures get pixelated and scrambled after about 1/2 hour, I was using a small fan to keep it cool until I finally found a replacement T-CON board. Bad LVDS driver IC on the main board can also be the problem. Right now we need to find out if it is heat related problem or not.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
