Retractable
leashes can usually extend up to 25-30 feet long. They are ideal for leash training puppies;
however they may not be the best solution for keeping your pet under control.
It's actually just kinder to your dog to get a longer leash. That way you give them loads of space to run around and feel free but you still act like a responsible owner. I think long leashes - the retractable ones that you can pull back in if you need to, are just great.
It's pretty simple to use a retractable leash, but check out this webpage that gives some basic instructions about how to use the leash so it's comfy for you and your dog. http://www.dog-obedience-training-review.com/training-a-puppy-to-walk-on-a-leash.html
That depends on the type of dog you have and how much he weighs. The retractable leashes are great but you need to have the right leash or it may not be strong enough to hold your dog. In general, small is for dogs up to 26lb, medium for dogs up to 44lb and large up to 110 lbs.
Retractable leashes are great as they let your pet run around on a long leash, giving them the sense of freedom but allow you to put the brakes on and retract the lead when you want to stop your pet from going any further.
A good old fashion leashis usually the best option. Theretractable kind has been known to harm small dogs and malfunction when youneed to restrain your dog the most. Also, retractable leashes are known to hurt dog owners as well.
It could be that the
leash became twisted when it retracted or that the spring that is used to
retract it has broken, first of all pull out the lead all the way and try to
slowly feed it back into the unit ensuring that it stays flat. If you have
trouble feeding it back in to the unit it could be the spring - this shouldn't
be too hard to replace by opening the unit. Undo the Allen screws on side of
retractable leash. Carefully use standard screwdriver to gently pry the top
from the bottom. Try to pry evenly on each side to avoid breaking the plastic
casing. Visually inspect parts for signs of damage such as burns, cuts, rubs,
tangles, frayed or worn sections. Check all sewn areas for loose, missing or
damaged stitches. Replace leash material if necessary.
