Because you have a scale that weighs in whole grams not parts of a gram. You need a more accurate scale like these which weigh to 1/00th of a gram (0.01 grams).
Unlikely that _you_ can. It is normally a factory feature. Depending on the use of the scale it has to be calibrated against a Government certified weight under laboratory conditions.
Apparently the Smart Weigh brand of products is a subsidiary of Better Basics.
I did not find the ACE150 model of the Smart Weigh digital postal scale for sale on the Better Basics website. Other Smart Weigh scales sold on the Better Basics site have user instructions availalbe.
Therefore, I suggest you contact Better Basics directly and ask about the availability of instructions for the ACE150 scale. This is the link to the page with the Contact Us information: https://www.betterbasics.com/searchresults#?query=ACE150
i HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
