it is how much power the motor has. In the old days people travelled on horses . One horse produced one horse power. So if you had a buggy with 5 horses attached to it you had a five horse power buggy. So your schredder engine has the equivalent power produced by five horses.
https://en.wikipedia.org/wiki/Horsepower
Have you changed the intake filter or pipes in any way, too much air could be drawn into engine, check ports, jets and float valve, adjust mixture screw to 4 turns out then adjust by ear half turns either way, check fuel pump return.
Hi Bill, Tried saying WHOA ? Assuming it's a 'parking 'brake,can you block the wheels and have an assistant apply & release it?look under buggy for movement at the other end. A cable or mechanical linkage near one end or the other should have a provision for adjustment.Use penetrating oil,'shorten' linkage to tighten & vise versa it could also be a 'shoe' type brake applying pressure to wheel[s[ or axle. trace linkage from lever to brake. Good Luck
IS IT MANUAL OR AUTO? IF MANUAL YOUR CLUTCH IS MOST LIKELY SHOT OR GEARS ARE BENT BE CAREFUL AS U CAN CHIP FLY WHEEL AND THATS A PAIN CAUSE IT CAN SHATTER UR STARTER AND THEN YOUR IN FOR A EXPENSIVE REPAIR IF YOU DONT DO THE WORK URSELF WITH TRANSMISSION CHECK THE FLUID IT MAY B LOW OR FLUID BURNT AND LET A DROP FALL ON UR FINGER IF METAL FRAGMENTS ARE IN IT U NEED TRANNY BEST OF LUCK TO U I HAVE BEEN IN UR SHOES MANY TIMES MANY DIFFERENT CARS AND TRUCKS AND IM NOT EVEN 50 YET :) POSS THE TRANNYS FLUID COULD B CLOGGED AND NEEDS CHANGING ,CARS ARE A NIGHTMARE I SEE WHY THE AMISH HAVE HORSE AND BUGGY'S
Hi, apply the brake.
Go round to front of buggy.
Hold the 2 large grey buttons on side of frame.
1 pushes down 1 pushes forwards do this & pull buggy down towards you, this will fold it as long as the brake is on.
