It happens that the rugs fade if they are exposed to direct sunlight. But overall, I think the slightly faded rugs look great. The same can be said for the large rugs that are sold in this vintage shop. They don't look new, but they are luxurious. That's the beauty of vintage home items. They don't need time to fit into the interior.
We just use nylon to create our rugs over at Southwestern Rugs Depot (https://www.southwesternrugsdepot.com/), which has fade-resistant material. Other popular types of fabric will fade over time (such as poly, jute, wool, etc.).
Most of the time the colors will pop right back out with a good cleaning , if you don't hav a carpet cleaner , get a hot bucket of water and 2 cups of laundry soap a hard bristle brush don't be afraid to get it wet rubb it down when dry you will be amazed!
There are lots of factors which are responsible of fading of your area rugs mostly rugs fade on the areas in which they are continuously in exposure to sunlight, good quality rugs do not fade under normal conditions the rug company also provides some years of guarantee on color of rugs.
How long your rug lasts depends widely on what type of rug you're buying and where you're going to place it. recycled plastic area rugs are type of rugs which are more durable as they are made from plastic. Despite them being made from plastic, these rugs has a cotton-like feel, which makes it comfortable enough to be use both indoor and outdoor. These rugs are stain resistant, UV resistant and washable. Visit our website to shop quality recycled plastic rugs and more https://lushambience.com/
Check the transfer belt, also get a air spray can, look for the opening to the laser unit inside unit on top side, spray opening to remove dust or toner deposits. Lastly check fuser, it should have a uniform coating on it, if it looks faded in the corresponding area of fades you will have to change. Hope it helps.
This is a cold solder joint in the signal section of the set. After it heats up, that problem area conducts better. Have an experienced electronic person reflow some solder on the board.
If the issue is occuring in the same place on all prints, try the imaging drum (can't remember if this printer even uses one) or the transfer belt/roller (not sure which it uses). If you phone Dell support, they should run you through troubleshooting and send you either of those parts free of charge if you are under warranty. If not, buy them anyways; they don't degrade over time (if kept in the dark) and can be saved for when the currently installed one runs out if you don't need it to fix this issue.
