The microwave stop with code H97 showed.
Https://www.shopyourway.com/questions/1009953
May need to buy a replacement microwave, as repair may be expensive.
It is an error code that means ether the magnetron or the inverter is bad.
SOURCE: why doesnt my oven work?
H97 can mean that there is a problem with the Inverter Board, and you may need to take it to your local Panasonic repairer for assessment.
SOURCE: microwave stopped working suddenly,the sreen reads H97
If your oven is out of warranty then i would suggest just getting a new one.
The code is for a bad controller circuit, and it would cost almost as much to fix it as it would to buy a new one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
SOURCE: code H97 on panasonice inverter
H97, mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these. Thanks, Midwest-tek
SOURCE: Panasonic Microwave Oven showing error
here is the link of how they troubleshoot this code they do not advise anyone to perform this test unless you know how to discharge the capacitors and there is also an extremely hi amount of electricity it might be best to call a service tech but you can have a look at the link usually that error pertains to the magnetron or the invertor haveing an issue http://www.applianceaid.com/micro_faultcodes.html
if you have any further questions message me back Thanks and please remember to rank how this opinion has helped it allows me to help others in the future in similar situations Thanks Rick
