Washing Machines Logo
o
oswyn carrington Posted on Oct 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there any way to change Hz from 50Hz to 60Hz.
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Nov 25, 2014
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898720
Points
3964
Not possible to do.
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Sep 30, 2012
SOURCE: can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG.
you must transform the 60hz to 50hz or 50hz TO 60hz.
God bless you
1helpful
I have a FG5700A McCulloch Electric Generator and the capacitor is bad. It is a CBB60 - 26uf - 500VAC- 50/60 Hz. Where can I get one of these?? Or a capacitor that will work? Thanks!!
Lots of places :>)
KENOWA TRUE LIFE 26uF MFD 450V 500VAC 50/60HZ ...
picclick.com > ... > Parts & Accessories > Other
Product Description: Premium UL Listed Metalized Polypropylene Film (MKP) 26uF 450VAC 50/60 Hz Generator Capacitor AVR for Kenowa & TrueLife Branded ...
generator capacitor - Amazon.com
www.amazon.com > generator-capacitor
Results 1 - 16 of 667 - POWER PRODUCTS CBB61 Generator Capacitor 35uF 34uF 32uF 400VAC 450VAC 50/60 Hz 40/85/21 SH. 5.0 out of 5 stars 5.
Kenowa True Life 26uF MFD 450V 500VAC 50/60HZ ... - eBay
www.ebay.com > ... > Parts & Accessories > Other
Universal 26uF MFD 300V 350V 450VAC 500V 50/60Hz Generator ...
www.cafr.ebay.ca > ... > Other
Translate this page Universal 26uF MFD 300V 350V 450VAC 500V 50/60Hz Generator Capacitor ... Capacitor CBB61 CBB60 36uF 35uF 33uF 31uF 400V 450VAC 50 Hz 60 Hz ...
capacitor 26 uf in Automotive ' eBay
www.ebay.ca > sch
Find capacitor 26 uf from a vast selection of Automotive. Get great ... Kenowa True Life 26uF MFD 450V 500VAC 50/60HZ Generator Capacitor AVR ... JKD CBB61 45uF 42uF 40uF 38uF 36uF 450V AC 50Hz 60 Hz Generator Capacitor AVR.
What is the frequency of Briggs and Stratton portable generator 30552-00 and if it is 60 hz and I wanna change it into 50 hz, Is it possible and how?
It be better to obtain an unit that already design for your area as it will the appropriate electrical outlets.
As for the 30552-00 would be 60 Hz with running at a governed speed of 3600 (3750 unloaded).
Being a two pole generator frequency is determined by dividing engine as follows. 3600 / 60=60. Engine is RPM is in minutes and must converted to seconds. For 50Hz operation the engine speed must be reduce to 3000 rpm (50hz * 60seconds = 3000 rpm)
2answers
HOW TO SWITCH 6260 TO 60HZ
6260 isn't a model number for any Ingersoll Rand generator.
Generally, though, if you have a generator that generates 50Hz and you want it to produce 60Hz instead, you adjust the governor to increase engine running speed by 20%... if the engine will tolerate that speed. The first thing you need to do is find out what speed the engine runs when it's under normal load. If that speed can't safely be increased 20%, then the generator head has been built strictly for 50Hz and there's nothing you can do about it except run a UPS between the generator and your load.
If the engine speed IS low enough to safely increase by 20%, then that's what you do.
1helpful
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
1helpful
How can i change my hitachi LED 55"TV from 50 hz to 60 hz
It will do it itself. If you were to play a PAL video through it at 50Hz, it will be fine and if you play an NTSC in simple PAL it will be at 60Hz and display a reasonable picture.
Hope that helps.
2answers
Does not work on 50Hz kenmore elite dish washer
If it was built for 60Hz AC power (American), it will not work on 50Hz power. The Hz, is the number of cycles per second, the electricity makes. If your motor & controls are wired for 60cycles, they will not get the proper electrical supple to work on 50 cycles. AC voltage goes from neutral to positive to neutral to negative to neutral, (one cycle) according to the country you are in. Some countries also use 230 or 240 volts, instead of 120 volts.
Sep 10, 2009 • Dishwashers
Banding adjustment option in digital camera
50Hz and 60Hz is frequency of AC power supply. If you are in usa, select 60Hz and if in uk, select 50Hz to avoid flickers of florescent tube lights in picture.
Will it work on 50hz?
best to call customer service 800-877-5032. if under a warranty would not want to lose it.
60hz to 50 hz
No need to worry about that. The direct drive on these turntables will adjust for hz setting automatically.
1helpful
2answers
50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
