My friend is a part time mechanic he gets his solutions
from www.reliable-store.com
he gets from their every single detailed info, instructions etc. on all vehicles, and manuals like service, repairs, parts, owner's, operations, maintenance etc.
U can get help from there
there is a girl at chat she can help you
Turning off the abs light is not easy to do even if you dissconned the battery the most comeon proble on a abs light to come on proble be n abs sensor each wheel has on you need to put it on a scanner autozone does it for free good luck hope this was helpful good luck
The high mount brake light gets its own signal from the brake light switch (on the brake pedal). Or at least the wire leaving the brake light switch will splice, one wire to the high mount brake light, and the other for the rear brake lights is routed through the turn signal switch, and coordinated there with the turn signal wires to the rear brake lights. The brake wires and turn signal wires share the same wire, and same filament in the bulbs. It is kind of complicated, but brakes applied with no turn signal, brake light wire goes from brake light switch through the turn switch and out to the bulbs. If brakes applied with turning signal, non blinking brake light wire goes from turn switch to rear light, while the turning signal wire will go through the flasher relay, and then to the rear light to cause blinking.
I hope that makes sense. It appears the problem may be in the turn signal switch for both the turn signals and the rear brake lights.
Normally all parking lights are controlled by the light switch. First turn turn on the parking lights and second turn turns on the head lights.
Are you sure it is not your break lights staying on? if this is your break lights - look at break pedal for break light switch staying on or not adjusted correctly. Does your car battery gets drained from your break lights staying on?
Turn the parking light and compare the brightness on all lights. Next turn the flasher and compare the brightness on all light. Some time light bulb like 1157 will be insert the wrong way and short the light to signal. second open the light socket remove the bulb and inspect for burn mark and rust(replace the socket.
Behind the carpet is the ground point, clean and tight the ground.
and last is the combination switch for light and signals.
Good Luck
have you set the light switch to the courtesy light position , with the ignition on turn light switch so light is on then turn switch so light is off ,open door if light comes on that is the courtesy position if does not close door turn switch to the last position then open door light should be on close door light off,TURN IGN OFF EXIT AN LOCK VEHICLE INTERIOR LIGHTS WILL STAY ON FOR A FEW SECONDS THEN SLOWLY DIM .watch them before leaving
Fuse sure didn't play, bulb is unlikely to be all bad. Check the turn signal switch, first find the turn signal switch plug, put the key to ON file, in trying to find a turn signal lamp switch wire (flash to the thread) will this wire with no light ON one side of the turn signal line connected to see if a turn signal light, the light is turn signal switch is broken, or the plug contact undesirable, don't light it is turn signal switch to light ON one side of the light path, in order to determine whether the light bulb is broken can open a small lamp or led brake lights to borrow their wire leads to a turn signal whether turn signal light, so you can determine whether the light bulb not bright side is broken.auto diagnostic tool.
If you activate the turn signal switch and you step on the brake pedal, the turn switch (on the steering column) deactivates the brake light to make the signal light more visible. The bulb for the stop and turn lights is the same.
Turn hazard lights ON. If they don't blink, replace turn/hazard flasher, If one or more lights don't come on, replace bulb.
Check fuse and circuit wiring for broken or loose connections. If all looks fine, check following:
If front turn lights work fine, check brake/turn bulbs.
If turn lights come on but don't blink, replace turn signal/hazard flasher.
If front and back turn lights don't come on, replace switch on column.
