I have an older Hussmann Mohawk 4 door cooler and one of the fans has stopped working. Have replaced a different fan 4 years ago. Need to order a fan but not sure model number. Can you please help
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life.
I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work.
With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself.
Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise.
It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler.
The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A)
The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster.
To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
It is possible the capacitor has gone bad, cause, possibly a power surge. Suggest replacing capacitor first and see if problem happens again then I would change fan motor and capacitor. Good luck on your repairs
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
first unplug unit for a few hours . remove back . under there there is a compressor and a fan plug in did the fan motor start itself ? if not touch blade a little , did it start now ? if so you have a bad fan motor ( real common with this cooler ) if the fan allways ran no problem you have a bad start relay on the compressor ( this is another real common problem ) you need to order a fan motor and or a start relay from vinotemp . on an order i made a week ago they had the motor but not the relay (relay kit ) it was on backorder , you may get lucky i just looked i do not have the phone #with me but you can fiind it on there website (thats where i found it ) good luck ps :on second thought dont play around , order the fan motor and the relay together no mater if the fan is working or not , even if it is it will not be for long Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
they have bushings in them that sometimes make noise when the motor shaft moves to a certain position. when you open the door it disrupts the airflow of the refrigerator and the motor shaft will go to a different position causing the noise to stop.
This is most likely due to dirt that has accumulated on the fan itself, making it unbalanced. Otherwise, do a visual inspection of the fan and see if you can see any physical damage. If you can not clean it or otherwise balance the fan back out - then you would need to get a replacement fan. You can call Danby at 800-263-2629 and order the part(s) needed.
