Won't finish rinse cycle,vibrating a lot,shows f7
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified.
SOURCE: whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
SOURCE: cabrio washer wont spin or finish cycle, gave ld
ld is for long drain,first did you pull the drain pump to make sure something wasn't stuck in it stopping it from turning or blocking the opening,it's the one on the right bottom as you standing in front of the unit,the on on the left is the recirculating pump,if so you can use a putty knife to open the top of the machine there are two spring clips on on either side about three inches in if you use a flashlight you can see where they are.push them in one at a time while lifting the top and be careful of the lid it will spring open as you lift the top.
Once open remove the tub cover (the white plastic cover around the top of the tub) after removing the recirculating hose on the left rear corner.
Then remove the center cap on the wash plate(agitator)you'll see a 7/16 bolt through the center remove that and pull the wash plate straight up and off. once you've done this you can lift the entire spin basket out.
Now you want to look in the bottom in the rear of the outer tub there is a cover over the drain with two screws in it if by this time you haven't found the issue (clothing stuck in the cover)then you may have a bad drain pump.
SOURCE: washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
