TV turns on but turns off in about 30 seconds, not sure why?
UPDATE as of 02-Feb-18
Mitsubishi WD65735 shuts down, shows red led on front panel.
Resolution:
Replacement Lamp with Housing for Mitsubishi WD-65735, WD-65736, WD-65737, WD-65835 (915B403001)
Amazon com Replacement Lamp with Housing for Mitsubishi WD 65735 WD 65736...
It works wonderfully it's brighter than it was before... had my Mitsubishi 65" TV since 2009 and counting. Loving it.
SOURCE: I need a PWB POWER SUPPLY for a WD-62525 MITSUBISHI DLPTV
1-800-553-7278, this is mitsubishi parts dept
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
SOURCE: My lamp on my Mitsubishi WD65733 DLP TV actually
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
SOURCE: Looking for a parts manual for Mitsubishi TV model
The ballast part number is 938P055010 . If you need the actaul manual for your model you can get it from the following link. http://servicemanuals.vstore.ca/product_info.php/pName/wd52531--wd62531/cName/mitsubishi-manuals
SOURCE: WHERE CAN I FIND THE BALLAST IN THE MITUSUBISHI WD 52532 MODEL
hint: the two pins the lamp plugs onto go directly to the ballast which is really a power supply for the lamp.
not clear from all you have said if ballast is the problem===these sets had a lot of issues; anything, even too much dust on the fans inside will shut it down...........
