Coby Kyros MID8042-4 8" Tablet PC Logo
Steven Edmonds Posted on Sep 29, 2014
I need my coby 4.3 7inch android to get back to its original preformance
Baz Hawkeye
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Oct 08, 2019
Baz Hawkeye
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
14308
Points
57
Sounds as though you have the same problem that I had, which caused me to switch to Apple, and I've never had a problem since.
Androids seem to slow down considerably with use. I think it's due to more dross and trash being stored on it, which we cannot see, plus a reduction in battery efficiency.
I got round it by doing a reset and re-installing the OS. It's a pain in the ****, but afterwards, it ran like it always used to, for about a month or so, then started to slow again. After six months of this, I bought an iPhone Best thing I ever did. Got rid of Windows pc, Android tablet and I'm all Apple now and they all talk to each other. Hope this helps.
Just got a MID8042 want to watch from portable hard drive, will this work? t
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB 4:3 ...
www.amazon.com/Coby-Kyros-8.../B0075W8Y1S
Amazon.com, Inc.Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 Capacitive .... The Coby Kyros MID8042-4 Tablet is a powerful and flexible internet and .... Simply connectyour Coby Tablet to your HD TV with an HDMI Cable is the ticket to .... I bought the Coby 8042 as a low cost portable device I could take with my while traveling.
Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ...
www.amazon.com/Coby...Internet-Tablet/.../B0093XT...
Amazon.com, Inc.
Rating: 3.1 - ‎1,377 reviews
Amazon.com : Coby Kyros 8-Inch Android 4.0 4 GB Internet Tablet 4:3 ... SANOXY® PU Leather Carrying Case For 8 inch Tablet Stand w/ USB ... With sleek and stylish Coby tablets, you can relax and enjoy your favorite music, 1080P HD videos, ..... Picksup home wi-fi & mobile hotspot (wi-fi from my phone) just great, never ...Missing: mid8042
How to fix kyros coby mid8024 tablet
Sounds like a corrupted kernel. The only thing you can do is download adb tools and then download the original Coby files for android. without having to do alot of research(if you dont know how to, you will have to research) you can go to Androidcentral.com go to the coby section, in the forum. There you should be able to find the step by step method. Sorry but this would be about the best help I can give you with out actually doing it myself.
1helpful
2answers
Need to change my settings back to english
use this manual refer to the icons and try to serch for the same in your korean or either count manual lines until you reach same position like in english How to Change the Language in Android
http://www.wikihow.com/Change-the-Language-in-Android
Coby kyros mid9742 screen is very dim
settings:
display:
brightness/backlight:
crank it up!
2helpful
I have a craig android tablet model cmp741e. it is stuck on the android start screen.. i can turn off then on with same result.
You need to re-install the firmware, not the original one, but a clean version that is available here: http://www.craigelectronics.com/firmware_update/android4.0/cmp741e_firmware4.0_cleaner.rar
Will reboot several times, and fail the first run, but it will work on restart. It has worked for me and at least 2 other people that I know of.
4helpful
2answers
Coby kyros mid 7022 is stuck on lock scteen, how do I get around this? Also goes into hibernate for seemingly no reason. Very new android user, no clue what I'm doing
Here is the instruction on how to do the factory data reset when a customer locks the system and lost his security password/pattern. This instruction works for MID7016 and MID7022. An end user must follow each step precisely. Otherwise, he/she will not access to the system menu mode.
  • Connect the AC power adapter.
  • Turn on the system.
  • Press and hold the power button until the popup window of "Device options" appears on the screen.
  • Select the "Power off" option from the popup window. You will see another popup window of "Power off".
  • Select the "OK" option. The unit will turn off.
  • While holding down the "BACK" button, press and hold the "POWER" button until Coby logo appears on the screen.
  • Release both buttons once you see Coby logo on the screen and wait for a while. The Coby logo screen will change to Android logo.
  • Wait about 15 seconds after you see Android logo. (Do not press any button while waiting. If you do, you will not be able to access to the system menu.)
  • Press the "BACK" button once. The system menu screen will appear on the screen.
  • Choose the "wipe data/factory reset" by using the "HOME" and "MENU" buttons. (The "MENU" button will allow you to browse down through the option list, while the "HOME" button will allow you to browse up through the list.)
  • Press the "BACK" button once you select the "wipe data/factory reset" option. The confirmation message will appear on the screen with YES or NO option.
  • Choose the "Yes - delete all user data" option by using the "HOME" and "MENU" buttons.
  • Press the "BACK" button once the "Yes - delete all user data" option is selected. It will perform the factory data reset. Wait until it is done. Once it is done, the main system menu will appear on the screen again, and the "reboot system now" option will be selected as a default. If not, you will need to select the "reboot system now" option from the list.
  • Press the "BACK" button to reboot the system. The system will reboot with the initial factory data setting. All user data will be lost.
Give the reboot at least 5 minutes. Do not assume the unit has frozen
9helpful
3answers
I bought a coby tablet mid7015 but can't access facebook from it,they said I should download the application by clicking onthe appslib icon but wen I do so nothing happens, it just keeps me waiting...
It might be the version of the Android on it. If you use Android 2.1, then you have to upgrade it to Android 2.2, then you will be able to play Flashcontent.
But bad news is, that you have to wait, until Coby releases an Android 2.2 upgrade for Kyros (http://www.androidtablets.net/forum/coby-tablets/3663-coby-kyros-7015-tablet-questions.html), because if you upgrade your tablet PC from elsewhere, then it might be malfunctioning.
Top Coby Cooking Experts
Billie Aukuso
Brian Kithinji
Brian Kithinji
Level 1 Expert
Meer Hadii
Meer Hadii
Are you a Coby Cooking Expert? Answer questions, earn points and help others
