SOURCE: noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
SOURCE: hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
SOURCE: Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
SOURCE: Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
