Engine turns over misfires but wont start
There maybe be many reason behind this spark. Short circuit, rusted metal or wire cut could be the major reason behind this spark. One of the best solution i would recommend is to buy a new robot lawn mower from moebot. https://moebot.com.au/moebot-s5-and-s10 These are affordable and efficient with their working capacity. Because repair might be costly and there is no chance that you may not face the same issue again.
Because people like Ned are on here giving advice
How old is this mower? Misfire meaning backfire? Recommend a compression test. Small engines, particularly the the b&S and TEC tend to cold,allowing carbon buildup on the valves and valve stems.
This causes the valves to stick open. The intake primsrily. So, several attempts to start is called for along with backfiring and frustration Remedy to this ail? keep everything in good order, carb adjustment, clean oil, clean air filterand most important, clean fresh fuel. Carbon will build up so there is no absolute fix. . It seems to be the nature of the beast.Working the enginepromotes shedding of yhe carbon on the valve seatsAt one time the practice of misting water into the intake broke the carbon loose. Interesting, I guess it workedRememr, I'm guessing it worked.
_good Luck _Ned_
How to Increase gas mileage?
http://schematicsdiagram.blogspot.com/2011/12/how-to-increase-gas-mileage-on-2011.html---------
For
car not changing gears it can be shifter assembly issue, or it can also be
transmission issue. Get the shifter assembly inspected with ignition OFF.
For
more troubleshooting, I suggest you to get the Following help link checked, its
complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition coil or
injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
From
start to end troubleshooting these problems I suggest you
to check the help link below and follow its procedure: -----
Mostly all types
of car no start problems are discussed here with solutions.
CAR NO START: ENGINE NOT TURNING
OVER:
http://alltypesofpartsreplacing.blogspot.com/2012/11/car-no-start-engine-not-turning-over.html
ENGINE MISFIRE
There are few possibilities that can cause engine misfire
issues. It can be issue with spark plugs or faulty spark plugs. Also get the
compression test done for cylinders. If any of cylinder shows low compression
then required, then that particular cylinder will cause misfire.
Also get obd codes scanned, the error code will let you know
which cylinder is misfiring or all cylinders are misfiring.
For your trouble shooting I suggest you to refer the help
oinks below. It has step by step details for many engine misfire issues.
Click the link below:-----
Ford Explorer Cylinder Misfire?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-cylinder-misfire.html
Engine Misfire codes on Chevrolet Malibu?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Cylinder 6 Misfire?
http://howtobyme.blogspot.com/2011/12/cylinder-6-misfire.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Ford Explorer 5.0L: Engine Miss?
http://whoisbyme.blogspot.in/2012/06/ford-explorer-50l-engine-miss.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
Can cylinder misfire Damage the Catalytic converter?
http://schematicsdiagram.blogspot.in/2012/02/can-cylinder-misfire-damage-catalytic.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Chevrolet K1500 No spark, random misfire
http://repairhelpcenter.blogspot.com/2012/11/chevrolet-k1500-no-sparkrandom-misfire.html
2004 Ford F150: Engine Misfire and Lean Code?
http://whatisbyme.blogspot.in/2012/05/2004-ford-f150-engine-misfire-and-lean.html
1995 Toyota LS: Misfire at idle or low RPM
http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Toyota Corolla:
Random Misfire?
http://technoanswers.blogspot.in/2012/04/toyota-corolla-random-misfire.html
2006 Ford Freestar: Misfire on Cylinder Number 2?
http://whatisbyme.blogspot.in/2012/06/2006-ford-freestar-misfire-on-cylinder.html
This will help.
Thanks.
