What do I do to clear this code
SOURCE: DMR-ES40V Error Code F03
If I may add to JoshOHoward's posting and with his indulgence.
The F03 (Fault 03) error indicates possible problem with your DVD's
mechanism, specifically the either the spindle or the transverse servo drive. This is the motor
and drive mechanism responsible for moving the carriage that contains
the optical reader/laser eye forward and backwards.
What perhaps you can try:
1. do a soft reset. With no disc, press and hold the power button for more than 10 seconds. Alternately, you can unplug the unit for an hour or so.
2. Do a force initialize. With no disc inside, eject the tray, close the tray simultaneously pushing on the back skip, pause and play buttons
3. Do a full hard reset. With the unit powered off, press and hold the Stop and Channel Up buttons while powering on the main unit at the same time for about 5 seconds.
If the above does not prove to be corrective of your concern, pls post back since further diagnosis/repairs require opening the unit.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
SOURCE: Panasonic DMR-EX85 code error U81
You will need to call Panasonic customer support for more information on this problem. here is their contact information. Accessories; or make Customer Service and Literature requests by visiting our Web Site at: http://www.panasonic.com/support or, contact us via the web at: http://www.panasonic.com/contactinfo You may also contact us directly at: 1-800-211-PANA (7262), Monday-Friday 9 am-9 pm; Saturday-Sunday 10 am-7 pm, EST. For hearing or speech impaired TTY users, TTY : 1-877-833-8855 Accessory Purchases Purchase Parts, Accessories and Instruction Books online for all Panasonic Products by visiting our Web Site at: http://www.pasc.panasonic.com or, send your request by E-mail to: [email protected] You may also contact us directly at: 1-800-332-5368 (Phone) 1-800-237-9080 (Fax Only) (Monday ? Friday 9 am to 8 pm, EST.) Panasonic Services Company 20421 84th Avenue South, Kent, WA 98032 (We Accept Visa, MasterCard, Discover Card, American Express, and Personal Checks) I hope this helps you with your problem.
SOURCE: Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
SOURCE: Panasonic dmr es40v came with wrong region code
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__5rtg6
