Babyliss Pro 10 in 1 Titanium Grooming System Logo
A
Anonymous Posted on Sep 12, 2014
How do I change heads on the babyliss 10 in 1 titanium groomer
How do I change the heads
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 25, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245591
Points
21965
How to change battery for a babyliss pro fx760
Hi! To change the battery for a Babyliss Pro FX760 hair trimmer, you will need to follow these steps:
  1. Make sure the trimmer is turned off and unplugged from the power source.
  2. Locate the battery compartment. This is typically located on the bottom or back of the trimmer.
  3. Remove the battery compartment cover by pressing the release button or sliding the cover open.
  4. Remove the old battery by gently prying it out of the compartment using a flat-headed screwdriver or a similar tool.
  5. Insert the new battery into the compartment, making sure it is oriented correctly and seated securely.
  6. Replace the battery compartment cover by sliding it back into place or pressing it down until it snaps into place.
  7. Plug in the trimmer and turn it on to test the new battery.
It is important to note that the specific process for changing the battery in a Babyliss Pro FX760 trimmer may vary depending on the specific model and design of the trimmer.
Note: The battery in a Babyliss Pro FX760 trimmer may vary depending on the specific model and design of the trimmer.
BABNT2091T
The Problem with BaByliss PRO Nano Titanium 1" Ultra Thin Hair Straightening/Flat Iron can be resolved if you call the company support line or web page.
Lost manual for babyliss 10 in one grooming kit
You should be able to get another one from the manufacturer. Try calling Babyliss customer service. Also, with the model number, a lot of manuals can be looked up online .
1helpful
Where can i send babyliss pro flat iron to be repair?
send it back to babyliss, their customer care hotline number is 08705 133 191 & Their email address is [email protected], please rate my solution
How to fix my shaver?
try going to their web site to see if they have a parts picture, if they do the diagram will probably resemble what the shaver looks like with the parts separated and numbered so you can buy just that part, it should give you an idea of what it looked like before. I know they have sewing machine pictures like that so I am hoping they have them for shaver too! good luck hope it helps.
On my babyliss type S47b, special screwdriver???
The screw may be triangular, or Torx (star pattern), or even 'pin-in-Torx', which all require special tools. They do it to prevent people from opening them up. But you can buy the tools, and for triangular screws I ground an old screwdriver down to match the shape!
Those screws are called 'Tamper Proof' or 'Tamper Resistant'. If you google those you'll find tool sets that will open dang near anything.
Nano Titanium babyyliss 720..no power,just quit
Hair dryer? You tried resetting the GFCI? The clicky thing on the plug. You'd be surprised how many people don't know to do that.
Babyliss have a bad habit of the cord going bad, right at the hair dryer. I've seen a lot of them. Once you get it open and slide the rubber cord-gripper thingy back, there's a melted or burned spot in the cord. You have to cut the bad part off and wire the cord back to the dryer. Normally once that's done, you never have any more problems.
Top Babyliss Pro Equestrian Experts
Imagdrider
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Babyliss Pro Equestrian Expert? Answer questions, earn points and help others
