Will the hp photosmart 7520 printer use 8x10 photo paper
SOURCE: HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
SOURCE: Paper jam in an HP Photosmart all in one 3210
look at the rear of the machine for an access door.
SOURCE: how to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
SOURCE: With HP Photosmart D7260 Printer, I get
Perhaps you are loading too much paper into the tray. Please try to work through the steps in this troubleshooter and see if it has any effect. If not, please report back with the results and someone will be happy to assist you.
HP OOPaper
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: My HP Photosmart C6200 All
None of the buttons on my 3 in 1 photosmart c6280 work but I can use to HP solution to get prints ,scan , and copy. Can not turn off or clear '! "button with out unpluging
THANKS
