Changing a password on an apple MacBook Pro laptop computer, I do not know my old password?
SOURCE: Mac Drivers for tethering an i930 phone to a macbook pro
Normally I would say use BlueTooth, but the i930 does not have Bluetooth.
I would look into using this software - http://www.pocketmac.net/products/devices/motorola_i930.html
SOURCE: USB flash drive not recognized by Macbook Pro
hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your pc.you can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
SOURCE: delete key on macbook pro won't work
you may have inadvertently set up a keyboard short cut on the delete key... go to your system preference app in the dock. Then select keyboard shortcuts... if you select "default" at the bottom of the window it will revert to the factory shortcuts and eliminate any you may have accidentally created...
Hope that solves your delete issue...
K
SOURCE: MacBook Pro Computer not in english
Here's how to switch it:
http://davidtse916.wordpress.com/2007/11/19/changing-the-system-language-in-mac-os-x/
You should be able to find the right things to click on based on their position in the menus, or the icons, which do not change when the languages do.
SOURCE: My MacBook Pro shows the message "Not Charging"
It could be either. Your best bet is to just take it to Apple and let them run a battery/adapter tester. That'll verify everything. Otherwise you can use a different battery and see if the same thing happens.
