The other pictures on the web show that there should be small holes at side of the links. They usually have arrows or another marking, and these are typically used to shorten a strap if needed. maybe here we can find out. Find out
Instructions
How to Take the Links off DKNY Watch eHow
SOURCE: Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
SOURCE: resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
