Watches Logo
A
Anonymous Posted on Aug 26, 2014
How to set dials on Invicta 9212 speedway - Watches
how to set dials on Invicta 9212 speedway
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Aug 28, 2014
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813003
Points
13579
Pull out crown and toggle with pushers. Soon you'll get it right.
2 Related Answers
Anonymous
  • 111 Answers
  • Posted on Sep 03, 2008
SOURCE: Invicta Gran Speedway CG second Hand reset
good after noon ! the hand of your watch is need to aline , so you need to go to the watc repairman,thank you! god bless !
Anonymous
  • 12 Answers
  • Posted on Jul 15, 2010
SOURCE: how to reset hour dial on Men's Invicta 9212 chronograph
See page 26.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
My Invicta reserve speedway won't keep time but the stop watch works need help
If the stopwatch is working but the timekeeping is not accurate on your Invicta Reserve Speedway watch, there could be several possible causes for the issue. Here are some steps you can take to troubleshoot the problem:
  1. Check the battery: A weak or dying battery can cause timekeeping issues. Try replacing the battery with a fresh one to see if it helps.
  2. Check the movement: If the battery replacement doesn't solve the issue, the movement (the internal mechanism that powers the watch) may be damaged or worn out. A professional watchmaker can diagnose the problem and repair or replace the movement if necessary.
  3. Check the setting: Make sure the watch is set to the correct time and time zone. You can refer to the manual or instructions for your watch on how to set the time and time zone.
  4. Magnetization: Sometimes, exposure to magnetic fields can interfere with the timekeeping of a watch. If you suspect that your watch has been exposed to a strong magnetic field, take it to a professional watchmaker for demagnetization.
  5. Water damage: If your watch has been exposed to water or moisture, it can cause damage to the movement and affect the timekeeping. You can try drying out the watch and replacing the battery, but it may require professional repair.
If none of these steps resolve the issue, you may need to take your Invicta Reserve Speedway watch to a professional watchmaker for diagnosis and repair.
How to set date
Usually you pull the time adjust out and keep spinning till you get the correct date in the window
2helpful
3answers
4helpful
2answers
Invicta Speedway 9223 not keeping time
It sounds to me as it is a quartz chronograph and it is right that the centre seconds hand moves only if the pushbutton is pressed. If you look close enough, you will notice that the small subdial finger is ticking and counting seconds. It is recommended to replace battery, as sometimes watches been laying in stores for a few years before selling and the battery is flat or underpowered.
Want to know more about your watch? Go to www.invictawatches.com and find out.
Regards
Arthur
1helpful
I have an Invicta 5103 mechanical wind chrono and the large second hand will not zero out on the 12
To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it.
1helpful
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
