Garden Logo
A
Anonymous Posted on Aug 23, 2014
Toro 266d runs five seconds then dies toro dealer just worked on two weeks ago
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,917 Answers
  • Posted on Sep 02, 2014
charles beach
Master
Level 3:
Renaissance:
Answers
1917
Questions
Helped
570498
Points
3010
Adjust fuel screw turn it one turn out see if that gets it running if dose turn it slowly in until throttle runs smooth the screw to adjust is the h screw on carb screw mark on top h or body will have a h on it turn it out one turn only but before that try to srart sqiuirt some starting fluid in carb sart engine leave choke off hold throttle wide open should run
  • Dave Vuckovich Mar 13, 2015
    I would take it back to the shop that made the repair and tell them it was not a good rr
1 Related Answer
Anonymous
  • Posted on Jun 30, 2009
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Lawnmower starts then dies
Let warm up if still does need new spark plug
Oct 26, 2019 • Toro Garden
Toro 40" walk behind pull start ran fine a week ago would not start changed fuel filter new plug cleaned carb and filter still won't start.
Try starter fluid to determine whether its a fuel problem or spark. Remove air filter cover and filter and spray a short burst (about 1 second) of fluid into carb throat (or as close as possible behind baffle C) and promptly pull starter cord.
k2-wjhtl5kbplr5vrmqusq1k4lm-1-2.png If engine fires and runs for a second or two then its a fuel/choke problem (compression is ok). If doesn't run, then more likely no spark but could still be a fuel or compression issue.
Apr 25, 2019 • Toro Garden
TORO 6.5 RUNS FOR 4 SECONDS AFTER PRIMING THEN DIES.pUT IN NEW SPARK PLUG,new gas,but after priming run for several seconds.. it dies again....can you help...sounds like dirt in carb??/ It had run...
Did you check the filter? If the engine doesn't get air they it could cause it to die out like that. Also make sure that there isn't anything in the air line to the carb.
Did you check the gas line and make sure that you are getting enough fuel?
2answers
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
3helpful
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
Have a Toro GPS5 600 lawnmower. Starts with Choke on, but dies if you move off choke. Also, runs fast and slow when blade engaged. I heard carb for this unit are no longer available. Help
3helpful
Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Top Garden Experts
Jay Finke
Jay Finke
john h
