I suggest you type on the command line of your computer or I phone wilbro carburetor diagram . It will lead you to a web page with a diagram showing the assembly
must be a small tiller to have a walbro carb on it most of these have a hole drilled in throttle cam ("D" looking thing on top) that the cable has a "L " hook that goes into it cable clamp must me loosed to allow a 45 degree entry of "L" hook into "D" plate
You need to determine if you have a Nikki or Walbro carb. The Nikki bowl is held on by two phillips head screws and the Walbro bowl is secured by either a single bowl nut or a anti-backfire soleniod (two wires going to it). Your problem is probably the seat in the carburetor. We see very few float problems since most of them are plastic.
If you have a Walbro with the anti-backfire solenoid you will need to get a slim 1/2 open end wrenc the access the "flats" on the solenoid to unscrew it.
The brass seat is replaceable in the Walbro along with the needle. If it's a Nikki, you may need to replace the carburetor.
you might find something at a dealer like www.arcolawn.com. most carburetor brands have lookups and diagrams on their sites allowing you to view by carburetor model.
For example
walbro carburetor wt256 typed into the search will pull up all the parts for that carburetor.
Look for the numbers and brand on the side of the carburetor and you will be set.
Good luck
Joe
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
