2005 Honda Shadow Spirit 750 Logo
A
Anonymous Posted on Aug 17, 2014
Remove stuck screw from crankcase coveron '83 Honda c110 motorcycle
Crank case cover, 6 Philip head srews
master zee
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 57 Answers
  • Posted on Aug 17, 2014
master zee
Contributor
Level 1:
New Friend:
Night Owl:
Answers
57
Questions
0
Helped
19395
Points
66
Hi! if you don't have a hammer-screwdriver (what is the right name?) just use a puncher + hammer: on the side of the head first punch a small hole, so the tip of the puncher is well held on that spot/hole. Then carry on with the puncher a bit off-axis (of the screw), to cause the screw to rotate a bit to the left. Then carry on. Some WD40 can help too. I got some great results like that. Good luck!
5 Related Answers
Anonymous
  • Posted on Mar 19, 2009
SOURCE: How do I remove the seat on an 84 Honda Sabre motorcycle
Hi there should be a lever on the left side of the seat towards the back, it doesn't look like a lever more like a helmet holder, move it up or down an the seat should come off
Anonymous
  • Posted on Apr 12, 2009
I have an 85 Sabre and was looking for an answer to this as well. I read the daniels solution. Not sure what Mr. Daniels is smokin but was he dead wrong. First, the helmet lock has nothing at all to do with this procedure. Why he thinks that is beyond me. Also, there is no "lever on the frame" to push forward.
So, after tugging a little here and there on my seat, I stumbled on the procedure. Here it is: 1) Remove the side covers off of each side of the bike. They are only held in place by grommets at 3 locations per side. A small tug at each of the 3 positions will remove them. 2) You will now be able to see a bolt on each side of the bike that secures the seat. Remove them. 3) Now it's technique time. The seat is now only held in place by a plastic tab and a steel tab. The plastic tab is part of the seat bottom at the front of the seat. The steel tab is on the frame of the bike. That steel tab goes into a slot on the underside of the seat. So here we go. Grab the back edge of the seat and firmly pull it rearward and slightly upward at the same time. That will disengage the molded slot on the underside of the seat from the steel tab on the frame. Once the seat has been disengaged from the steel tab, you can angle the seat upward. Once the seat is angled upward about 30 degrees, pull the seat in a rearward direction to disengage the plastic tab on the underside of the seat from the frame of the bike.
Since the air cleaner on a Sabre is underneath the fuel tank, all Sabre owners who do their own maintenace have to know how to remove the seat. One of the fuel tank bolts is hidden under the seat, The other two are on the front sides of the tank.
tombones
  • 3567 Answers
  • Posted on Jul 24, 2009
SOURCE: needs a new crank and crankcase lefthand side
You have a couple of options. Have a professional welding shop weld the aluminum case and then all that is left to do is to replace the seal on the output shaft. This will probably cost about $50.00.
Second option would be to Google " motorcycle salvage honda " and find what you need there. If you replace the broken left casing, also replace the right center casing. Slight changes in manufacture during a production run sometimes occur. This means the casing halves may not line up perfectly causing the shafts not to turn when the engine id put back together. ALWAYS replace center casings as a matched set.
Anonymous
  • 2050 Answers
  • Posted on Jul 01, 2011
SOURCE: over torqued and snapped off the head of the oil
Is the remainder of the bolt still in the threads??? Get a good bolt extractor to remove it.
If the remainder has gone in the engine, if you can't get at it with a magnet (get it to the hole and thread it out) you will have to get the engine split.
Anonymous
  • 440 Answers
  • Posted on Jan 07, 2012
SOURCE: How do I remove the battery from a 1985 Honda Gullwing motorcycle?
I guess you mean 85 Goldwing GL1200Under LH side-panel unscrew retainer screw above battremove leads neg 1st, remove breather tube, pull battery out top 1st
Ride Safe
Bike-Doc
Testimonial: "Yes thank you very much. Easy as pie when you know how."
2005 Honda CRF250X - Dirt Bike. Torque specifications for crankcase bolts on 2005 crf 250x
Question edited for clarity.
Question moved to model category.
Torque Specifications - Honda CRF250X Owner's Manual ...
ManualsLib https://www.manualslib.com > manual > Honda-Crf250x
Honda CRF250X Manual Online: Torque Specifications. ENGINE Torque Item N•m kgf•m 1 Cylinder head cover bolts 10 1.0 2 Exhaust pipe joint nuts 21 2.1 3 10 ...
Crankcase Torque Spec.?? - CRF250R & RX
ThumperTalk https://www.thumpertalk.com > forums > topic > 8357...
Nov 5, 2010 - 12nm, 9ft lbs or 108"lbs. Don't use loctite on the case bolts. Use some blue loctite on the kick start bolt, that usually the one that comes ...
torque specs please service manual guys - CRF250X
Oct 28, 2009
Clutch cover and Crank cover Bolts/torque? - ThumperTalk
May 17, 2006
Bolt torque specs - CRF250R & RX - ThumperTalk
Aug 10, 2007
bottom end torque specs - CRF250R & RX - ThumperTalk
May 20, 2009
More results from www.thumpertalk.com
Left side cover torque specs 2005 crf 250
CRF's Only https://crfsonly.com > forum > viewtopic
Feb 25, 2012 - Hey fellow red riders I'm having to change my left side cover and can't find the torque specs for the left side cover bolts and if the ...
Torque Spex - CRF's Only Forums
Jun 21, 2007
CRANKCASE BOLTS TORQUE - CRF's Only Forums
Apr 18, 2017
Torque Specs 2006 CRF250x ? - CRF's Only Forums
Jul 1, 2009
Washers and Bolt Torque - CRF's Only Forums
Apr 9, 2017
More results from crfsonly.com
HONDA CRF250X
Honda http://owners.honda.com > 2005 > 2005_crf250x
side cover bolt (8). 6. Install the collar (7) and seat bolt (9) tighten the bolt to the specified torque: 20 lbf·ft (26 N·m, 2.7 kgf·m). Servicing Your Honda.
180 pages ..
How to adjust a clutch on a 83 Honda 250 dirt bike
IF CABLE, loosen the lever end right off, then remove the engine cover where it enters, a 10mm nut will be visible, and a flat screw head, use a screw driver to hold it tight, and 10mm to slacken the lock nut, using screw driver tighten to just a stop, then loosen quarter a turn, lock 10mm nut, keeping flat screw driver holding the head tight, same as any cable bike clutch.
1helpful
How to replace piston rings on honda 6 horse motor
you need to remove the pump then the end cover from the engine remove the cylinder head the unbolt the connecting rod push out the piston hone cylinder and then wash the motor out with soap and water i use tide clothes soap and hot water put it back to gether now why does it smoke check the head gasket the over head engines blow head gaskets and **** oil from the crankcase
How do you change a clutch on a 85cr
1) Release the pressure on the system by unhooking the clutch handle from the cable
2) Identify which side of the crank holds the clutch mechanism. Probably opposite the chain drive sprocket which means the clutch is on the right side as you sit on the bike. Spray off sand or grit that may fall into the works as the case cover comes off.
3) Drain the gear case oil
4) Remove the kick starter by removing the bolt holding the lever onto the starter shaft. Carefully, maybe with a impact driver screwdriver, loosen and remove the screws holding the round clutch cover from the engine crankcase. There are probably five, maybe seven, Phillips screwheads or maybe with ten mm hex heads. They will be different lengths so remember which holes each came from. I always replace screws with hex head bolts 'cause the screws can be a pain to remove.
5) Remove the clutch cover. You may need to remove the footpeg. there may be a steel ball bearing about 8mm diameter roll out of the center of the basket, so watch for it.
6) The clutch will be covered by a 'basket' held down by probably six bolts recessed into the basket.
7) As you remove the basket, you will find rings made of metal alternating with rings of fiber. Remove these, noting the order. If the metal rings are not blued or scratched, you can use them again. The fiber ones will need to be replaced, at about $7 each. Oil them and put new fiber rings back, starting with fiber and ending with fiber. I smear oil on the fiber plates before I put them in. You will see notches in the teeth at the edge of the fiber plates, and want to not line these up with each other.
8) Put the cover back, usually using a new gasket, or at least silicone. Leaks here make a mess and it's worth taking time to get it sealed.
9) Fill with amount of oil specified on the side of the crankcase. Make sure you use 'cycle oil, with MA rating. Auto oils will allow the clutch to slip, and make it burnout quicker.
I need to know how much crank oil goes in a 1991 Honda CR 250R?
There is a phillips head screw on the clutch cover right below the water pump. Remove this screw and add oil til it runs out the hole where that screw goes.
Fuel leaking out of the crankcase
Sounds like the float is stuck in the carb.. its not really pouring out of the bottom of the cranks case.. its an overflow hose that is routed down through the motor so it will drain out under the bike.
You probably need to pull the carb and clean it, and check the float.
7helpful
2answers
Changing clutch plates on a 1994 KE 100
All you need to do is remove the right crankcase cover then remove the clutch cap and springs then the friction plates and clutch plates. Note that a friction plate is both the first and last plate in the clutch and that a pressure plate is in-between each friction plate. Friction plates are fiber, pressure plates are metal. No case splitting is required.
You may want to get a 3/8" impact driver to remove screws and hex head bolts and to tighten them back up. I find it to be the most useful tool in my shop. My Bluepoint brand impact driver is 40 years old an as good as new.
Please rate this answer. Thanks kettnerrequip!
How to change handle bars
Take off the screws under the stearing lock cover that says (lock unlock) if they are not philip head screws then they most likely are torx heads you can purchase a set of torx screw drivers at your local auto parts store.
2answers
Discs won`t come off Honda
Did you remove the two phillip head retaining screws that hold the rotor to the hub? Also, if there is alot of corrosion around the center of the hub, the rotor might be stuck in place. In that case, you'll have to tap the rotor with a hammer to break it free.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
