Are you sure the code is c-1133. According to our docs, this code is invalid. If you need anything else, just drop us an email at [email protected] Also, please visit our websites, we're sure you'll find useful things there --------------------------------------------------------------- Konica Minolta Error Codes & Solutions -http://www.kmcodes.com Drum, Transfer Belt and Fusing Unit Firmware Reset -http://www.bizhubreset.com Drum and Toner Chip Reset -http://www.chipreset.eu Transfer Belt and Fusing Unit Reset Kit -http://www.resetkit.euAre you sure the code is c-1133. According to our docs, this code is invalid.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
You can't post conmments that contain an email address.
www.fixya.com/support/t21602993-error_e733_0000 Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
HO2S slow responce bank 1 sensor 1.
This means an oxygen sensor bank one is the first O2 sensor in exhaust manifold off #1 cylinder .The code is PO133.
You should change your fuel filter then do a tune up plugs cap rotor wires if requeried and pcv valve along with air filter.
This is if you haven't already damaged your catylitic convertor or your fuel pump .Vehicles need to be serviced if you want dependabulty if not buy a new car every couple years or so
Error code p1133 indicates faulty O2 sensor on Bank-1
sensor-1. The problem may rise due to faulty or damaged sensor wiring. Also
defective O2 sensor may be cause of problem. First thing you should do is to
inspect the wiring and connectors then go for replacing the O2 sensor if wires
don't work.
code P1133 is for a problem with 02 sensor bank one sensor one. this is the left 02 sensor in front of the cat. converter. code P1153 is for a problem with 02 sensor bank 2 sensor 1, which is located on the right side of engine in front of the cat. converter
