I've touched my 150cc taotao paladin scooter solenoid with a screwdriver and it still won't start what else could it be @
SOURCE: 150CC Roketa Scooter
Hi and welcome to FixYa,
On most versions of Roketa 150cc engines, the choke is automatic and electrically driven.. It is integrated with the carburetor.
Good luck and thank you for asking FixYa.
SOURCE: Where is a battery located
The batter is underneath a panel with four screws (1 recessed) located underneath the mat where your feet go.
SOURCE: Taotao battery won't charge .
Whenever you have issues where the battery isn't charging it is most likely the fact the the battery is bad,m or maybe theres a short somewher e aolong your currents path. Check to see that your chareger isn't broke, and you can do this by using another person's charger to determine the life of your own battery. If it charges with the other charger then that's the sign you need, so that you can replace the current charger.
SOURCE: why does my 150cc taotao scooter stall when i give it gas
Replace the spark plug or replace the gas filter. Check your spark plug wires for corrosion.
SOURCE: why wont my linhai scooter idle with a taotao scooter carburetor
The carburetor has the wrong idle circuit jet fitted or incorrect idle screw adjustment.
