Tv just turned off, plugged into different plug, then did the 5 minutes and more turned off tried to turn on with the remote. but still nothing. Help!
SOURCE: RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
SOURCE: my rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
SOURCE: RCA R301F1 remote problems
If you have tried 5 remotes I would have to say that the set has a problem in the remote circuit. You will need a tech to look at it and repair it. Let me know how this works out for you.'
hardrocko
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
SOURCE: RCA L26WD12 26IN, LCD TV will not turn on, the red
It can be due to unstable DC power from the power supply due to bad caps, or bad main board (I had to replace my main board, and later on the inverter boards). You may want to think about putting money into this TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://s807.photobucket.com/albums/yy352/budm/RCA%20L26WD12/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
