Http://www.fixya.com/support/t26064144-when_e4_error_appear_will_problem
Quoting prior FIXYA question:
Defy top loader. What is e4 error? - Washing Machines
Posted by DENNY TAREMBA on Jan 22, 2016
Anonymous
Generally the E4 error means that the tub is unbalanced. You either filled the washer unevenly, or you are trying to wash something too heavy or too large. Take everything out of the machine, and then re-arrange it and put it back in. If you are still getting the error, you need to wash less clothes at a time.
Another possibility is that your sensor needs replacing, the sensor that tells you how full the tub is and when it's off balance. For that, you need to call a repairman. Posted on Apr 07, 2017
I need assistance with pressure switch e4 error
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: My ge fuzzy top loader
http://www.scribd.com/doc/22404529/GE-Hydrowave-Top-Loading-Washer-Won%E2%80%99t-Run-Washer-Repair-Fixitnow-com-Samurai-Appliance-Repair-Man
above is a repair tutorial to do with that error DE.
dE - Lid open error
Lid is open during wash cycle.
Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board
SOURCE: What is the problem if
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
