Did you mean you want sim network unlock pin to remove your T-Mobile network lock?
Yes means visit SuperUnlockCodes.com Here you can get your sim network unlock pin through E-mail by specifying your mobile model no,country,network provider.
SOURCE: Unlock code
the unlock code should only be 8 digits long. before powering up the duo, you must have your t-mob SIM in, then power up and you will be prompted to enter the code. I unlocked one today, and it works, but I am having problems getting the t-mob SIM conatcs loaded to the duo's contact list.
SOURCE: need unlock code for lg ks360 mobile phone
Hi Friend,
Kindly follow the instructions in the below mentioned link and you can find by your own the unlock code
http://www.pb4kn.co.uk/ks360_unlocking.htm
If this is helpful and solved your problem kindly rate this
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: the t mobile samsung t219 unlock pin code for sim
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
SOURCE: i need a sim pin to unlock my t-mobile sim card?
as of this date- don't know if apple allows any other service than at&t (rip-off!!). believe in the near future they will expand to other networks, but as for now- not sure! check with your apple web-site for the iphone smartphone!
good luck!
SOURCE: I have a simple mobile
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -
The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
