Replaced thermostat and the cooler continues to fall below 30* at its lowest setting.
You killed the messenger! The refrigerant charge is probably the problem. The thermostat senses the coil temperature and not the cabinet temperature. If somebody put gas in it, the gas has to be removed, a vacuum drawn on the system and then the refrigerant charge weighed in by the ounce. It takes a critical charge and needs to be weighed in by an accurate scale that weighs in ounces. Hope this helps and good luck.
SOURCE: beer cooler keeps freezing
Could be but sounds like it may be low on gas. What emp do you set it at. Should be about 35 degrees if you have it set to low it will ice up on you. Russ
SOURCE: My beverage air MT45 is
if the door is not cloosing properly and need to be adjustment how do u adjust it
