I need the torque specs on the bolts for the intake manifold on my Briggs & Stratton engine model 44m777-1193-b1. I had to replace the carburator. I have to wait on the seals for the intake so I figured I'd get the torque specs while I'm waiting.
If there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
SOURCE: 123602-0131 BRIGGS & STRATTON ENGINE. NO LOW SPEED
Problem solved by replacing to two mentioned parts. I was told that sometimes it is also necessary to replace the camshaft as some of the plastic teeth on it could also be damaged.
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
SOURCE: I have a Briggs & stratton 18hp ohv riding
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. [email protected]
SOURCE: briggs & Stratton 18 hp v-twin engine surges
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
30 foot pounds would be a over kill you would be replacing the manifold
