Refrigerators Logo
A
Anonymous Posted on May 17, 2017
Why does my new Crosley refrigerator smell like oil in the freezer section?
Just bought a new Crosley refrigerator and noticed right off the internal temp was at 56. Repairman came out and said it had been sitting long enough in a warehouse probably and the fan was frozen up. He said if I had anymore problems he would replace the fan. After he left everything seemed to be working fine and temp is now at 39 but have horrible smell in the freezer section blowing down into the food section. Smells like oil ....maybe...concerned my food will pick up the smell and taste funny. any ideas?
Gil Shultz
Level 3:
  • Refrigerators Master 3,464 Answers
  • Posted on May 17, 2017
Gil Shultz
Level 3:
Answers
3464
Questions
Helped
730719
Points
11104
Get it replaced or paint it lemon yellow. If they argue ask for your money back, if that is a problem contact your BBB and the manufacturer. It comes with an implied warranty to perform.
5 Related Answers
roadrunning1
Paul G
  • 161 Answers
  • Posted on May 10, 2009
SOURCE: smells inside freezer and refrigerator even after thorough cleaning, smell is even penetrating food and making it taste bad
First of all , empty out the freezer, leave if off until it fully heats up to room temperature, Clean it out with Vanilla essence and turn back on. Allow the freezer to reach operating temperatures before putting anything in and before you do check to see if the smell is stil there.
Now if it is it means that the freezer's insulated internal wall is damaged and it has allowed seepage out into the bottom trapping some old juices (blood and anything else which may have leaked during a defrost cycle) which have leaked out and constantly breeding underneath the freezer. If this is the case either, find leak and seal it with some good quality mastik sealer not silicone !! or: buy a new one , unfortunatly if it is damaged repair may not be the best solution depending on its age and brand. I hope this helps>
jvernice
Joseph Vernice
  • 63 Answers
  • Posted on Jul 29, 2009
SOURCE: bad smelling water
The water lines are contaminated with bacteria and/or mold. This is a problem with many refrigerators. You need to turn off water and disconnect the feed line and filter. Mix 4 ounces of Clorox(R) in 1 gallon of water and pump it through with a NEW garden sprayer. You can remove the wand and clamp it onto the water inlet. Activate the dispenser while you pump the bleach through the system. Once bleach starts coming out the dispenser, vent the garden sprayer (de-pressurize), Let the bleach sit for 15-20 minutes. Re-attached water using a brand new filter (do not use the old filter and do not put bleach through filter). Run water until no chlorine odor (it can be a while). This process needs to be done at least once a year.
Anonymous
  • 998 Answers
  • Posted on Aug 17, 2009
SOURCE: Refrigerator and freezer musty, freezer burned smell? ?
they should be washed every2 months use baking soda and a box of fridge charcoal
thumbs up
Anonymous
  • 4793 Answers
  • Posted on Feb 23, 2010
SOURCE: My refrigerator smells horrible! And there isn't
switch it off.manually defrost whole unit,clean all vents/drain holes, wash interior out with bicarb and dry well.leave door open for 12/24hrs to dry out then switch unit back on and leave (empty) to settle down to operating temp 32/36f is normal for a fridge.then load up as usual.smell like wet cardboard/felt ? is "grow your own penicillin".
Anonymous
  • 274 Answers
  • Posted on Jul 26, 2010
SOURCE: Freezer area smells and ice cubes and butter taste off?
It sounds like the ice maker if equiped. Remove Ice bin and clean out,and try a lite spray of bleach or vinegar (don't mix) If the smell is still happening and comming from ice you may want to install a inline filter.
I have a Crosley top-freezer refrigerator and the refrigerator is fine but freezer is much too cold, even at the warmest setting
i dont see how a freezer is to cold? but if it is always running you will need a new cold control
The refrigerator door was left ajar for several hours. then the ref cooling system was not functioning right after the incident. although the freezer is still doing its job Im worried if its beyond repair....
When the freezer section gets cold and reaches its required cooling temperature,after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge.But if the defrost cycle does not start then freezer will block the air passing section from freezer to fridge,so the freezer gets cool but fridge section does not cool. Its the defrost problem.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check,if the same problem is noticed again,.If yes then its defrost board problem.The defrost board located in the back of fridge section.You can get required parts from www.repairclinic.com or from online sears part site.------------- Thank you.
I have a Crosley CT19G6W Blower is going but is has stopped cooling in both freezer section and refrigerator section. This happened in one day.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Funny smell coming from under my whirlpool, side by side fridge freezer. I've often noticed this smell in shops with freezer sections. The only thing I can liken it to is stale ****!! Sorry!!
the smell is urea,it is the gas they use to make the injection mouldings (plastic and foam) it is HARMLESS,but does smell like **** cos its the same gas.........(the best leather is processed with femail ****.)use male **** to accelerate your compost heap... if you think im joking try it.....
I can smell items in my freezer when I open the door of the fridg
Good day,
All cooling in a refrigerator, be it the freezer section, or the fresh food section is performed by the freezer.
The freezer takes care of itself, but also by the function of the fan motor in the freezer, blows a limited amount of the freezer air into the fresh food compartment to cool it to the nominal 37 degrees.
The odor in the freezer is disguised by the extremely cold air, and is not apparent. But that odor when raised to 35 or 40 degrees will become noticeable.
As well, the freezer compartment rises to 30 degrees plus when going thru it's automatic defrost cycle, which occures for approx. 30 minutes once or twice a day, adding to the problem.
Sealing the packages is probably the only real answer.
Thank you for using FixYa.
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
1helpful
2answers
Frisdge/freezer and ice smell
I had a side by side refrigerator with an Ice maker from Sears. The ice it makes smell fishy so bad that I could not use to drink with anything else but throw away to the plants. So I unscrewed the ice maker . It is not that bad, but quite simple to take it out. I noticed rusted pieces of metal generating strong fishy smell. I could not get rid of rust with soap, detergent, oil so I wrap it in plastic bag then screw it back into the refrigerator. Screwing back the ice maker. Voila. The smell is going away. The ice is good. Pina Colada and Daiquiri here we go .
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
