SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
SOURCE: My Elna 6005 Heirloom
When you switch sewing modes, what does the display read as far as the stitch type you are using?
SOURCE: What foot do I use for strraight stitching I have
Ideally you want a foot that looks like this with a very small hole where the needle goes down, to maximise the pressure onto the fabric. Just don't move the stitch setting to anything that swings the needle or you'll smash the needle onto the foot and risk damaging the machine.
But unless you are having issues with the fabric being pulled down into the feed dogs, the regular clear sewing foot should be fine for most work and is certainly easier to see what you are sewing.
A lot of quilters go for a 1/4" foot too which gives you consistent 1/4" seam widths when piecing quilts. There is a excellent website on sewing machine feet and their different purposes, link is
http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ and she has great images of 1/4" foot in use along with others such as Open Toed or Roller foot.
If you are shopping for different machine feet, you may like to look at www.sewingpartsonline.com, great website with lots of different brands. Your machine would be classified as a "low Shank" machine I think; often you can buy a generic brand foot which will work on different brand machines once you are sure of the shank type.
Most sewers find that there will be one foot they prefer to use for much of their work depending on their projects. My all time fav is the Elna Teflon foot, a black teflon coated foot which works great on many different fabrics; I've worn the black off the bottom of two of them!!
SOURCE: My elna quilters dream machine has 84o test mode on display and I can't select other stitches
you might think about having the machine check to see if there is something wrong with the motherboard
SOURCE: Older Elna machine-black stitch discs, how do I
These discs are either single or double discs, the doubles give forwards and backwards movement by the feed dogs moving the fabric as well as side to side movement of the needle. This gives you the "Supermatic" stitches, revolutionary in 1952 when Elna developed this technology.
I'm assuming that you have a Supermatic (green) or Star Series SU (white with blue top) Elna model? your model will have a code number on the side plate by the power point, it may be 62 if its a Star, there is some variation in how you select the automatic stitches between these models but the basics are similar.
Start first by turning the stitch width selector to zero and stitch length selector to zero.
You need to insert the disc into the Elnagraph carefully, lining up the dot marking on the disc with the finger within the elnagraph, there is a little hole underside of the disc where this finger goes into to lock the disc in place. You now turn the stitch selector to "A" for automatic, and turn the stitch width to 4. Always turn your dials back to zero before removing the disc as there is a little feeler that swings over to "read" off the disc and you won't want to damage this.
The very early Elna supermatic take a slightly different disc, the finger hole is slightly different to the later machines and they were removed using a little tool. Later models it got easier and you push the middle of the elnagraph silver ring to release the disc.
I hope I haven't confused you more, you may want to join the Swiss Elna user group called Elna Heirlooms under yahoo.com groups, its a very helpful group of members and you should find a thread on these machines there.
