Cars & Trucks Logo
A
Anonymous Posted on Jul 14, 2014
I need the routing system for the serpintine belt for a 94 dodge grand caravan es 3.3 liter v6
A
Anonymous
Google it
There are pictures or diagrams on the internet
Next time make a diagram-- before you remove any belt
Should be a diagram under the hood on most vehicles
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Nov 03, 2008
SOURCE: 2004 kia serpintine belt routing diagram
Notes 98650681
K W
  • 509 Answers
  • Posted on Jan 03, 2010
SOURCE: I need a diagram for a 1994 dodge grand caravan se
Try this
Testimonial: "you did find the diagram that works, thanks."
Patrick Rayome
  • 1757 Answers
  • Posted on Jan 22, 2010
SOURCE: Need serpentine belt routing diagram for 1994 Dodge grand caravan
3.3L?
Looking at the engine from front (right side of the Van): Stating at the Top, Going Left to Right and Clockwise:
Over the Alternator
To under the Idle Pulley,
To Over the AC Compressor.
To the Left Side of the Water Pump.
To the Right side and Under the Crankshaft Pulley
To the Right side and Over and Down the Tensioner
To Under the Power Steering Pump
And Back up-to the Left side of the Alternator.
Advise when puting it on:
Put the Belt around everything else accept for the Alternator. After it is around all the rest of the Pulleys - Pull the belt up - tight from the Power steering Pump and the Idle Pulley to form a loop, holding the Belt close to the Altenator Pulley.
Using the 15mm wrench or belt tensioner bar - rotate the Tensioner Pulley towards the front of the Van and then place the belt over the Alternator.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on May 19, 2010
SOURCE: need a serpintine belt routing diagram for a 2006
2006 TOYOTA 4RUNNER - V6 4.0L 3956cc GAS FI N 1GRFE
Belt Routing Diagram - Multiple Accessory, w/A.C.
From DAYCO Products Catalog
Hope help with this (remember rated this post). Good luck.
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Jun 01, 2010
SOURCE: i need the belt diagram for a 3.3 liter V6 1994
Heres a belt diagram for your 1994 dodge grand caravan with a 3.3 engine, hope this helpful.1312666.gif
3helpful
2answers
I need the belt diagram for 94 dodgegrand caravan 3.3
But the belt at Autozone and the belt routing diagram will be on the box.
2answers
Want to bypass powersteering pump on 94 grand caravan 3.3 liter 6 cylinder, pulley making loud noise need new belt size and serpintine diagram if its possible
that's not possible all of those vehicles came stock with power steering so all belt dimensions are taking the power steering pump into consideration,the only one that would change would be the A/C belt depending on whether or not your vehicle came with it or not,a used power steering pump should only cost just a little bit more then a new serpentine belt,hope this helps and good luck
21helpful
2answers
I need the belt diagram for a 3.3 liter V6 1994 dodge grand caravan le
4helpful
Need a serpintine belt routing diagram for a 2006 toyota 4runner with a 4.0 liter engine
1helpful
Serpintine belt replacement
OK, click on the link below to be directed to a full size photo of your belt routing diagram.
2000 Grand caravan Serpentine Belt Routing
Please rate and have a great day:)
1995 plymouth voyager.i need serpentine belt diagram.its no longer under hood
Find a pic of routing here:
http://www.2carpros.com/forum/1992-dodge-caravan--serpintine-belt-routing-map-vt170348.html
Good Luck
Dean.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
