What is the top cap with the numbers used for it does not move anything?
SOURCE: I have a Bushnell Sportview 3-7X20mm scope on a
most likely you will have to send the scope in to have this taken care of to contact bushnells customer service at 800-423-3537. press option 1. the age of the scope necessitates sending it in to have parts matched up.
SOURCE: just bought a marlin 336 rifle (used) with a
Here ya go. link to the users manual.
If for some reason the link doesn't work, go to Bushells site and you will find the link to get a user Manual for this scope. hope this Helps.
LINK
SOURCE: I have a Bushnell Sportview 4-12x40 on my rifle
I just took my Sportview 3-9x50 scope apart for same problem. Found that the groove that phillips screw rides in got compressed somehow. With a little prying, I was able to open it back up. THIS IS NOT THE ADVISED WAY TO CORRECT!!!!! Bushnell has a lifetime on this product and will gladly help you. I just f*&^ed my warranty out the window, but need scope Nov. 7 for opening weekend with my daughter!! Good hunting, Pete
SOURCE: Need the rubber eyegaurd for a Bushnell Sportview
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
SOURCE: Hi, just bought a rifle with a bushnell sportview
you'll see two horizontal crosshairs, put the top one on the animals back then zoom in until the bottom one is on his stomach. Look at the numbers on the zoom dial there should be three lines they are D - deer, E - elk and A - antelope. The numbers are the distance to the game, you then turn the external elevation knob or turret to the matching distance and shoot dead on. No need to hold over for bullet drop. The sad part will be if you didn't get the other turrets that would have come with it as they are calibrated to different calibers and bullet weights.
