SOURCE: Lost installation disk for canon pixma mp780
Go to this link. Wait a few seconds for all the files to load. Select your OS in the box, then wait a few more seconds, and you will see the drivers displayed.
You will need to download and install both the driver and the MP Navigator (under the Software heading). Click on the link and follow the instructions to install.
SOURCE: My Canon Pixma MP780 is saying "waste ink absorber is near full"
Under the place where the inks park is a tray full of asorbent pads. It was the most awful thing to get to in my Pixma ip 2000. If you have a day to spare, and a work table, and some long needle nose pliers or maybe hemostats, and the usual tools, you can take the machine apart to get at it. Note which pads (and parts) go where, everything has to go back where it came from. The pads will rinse out with water, lots of it.
SOURCE: The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
SOURCE: how do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste
ink from cleaning the print head. Over time, this pad fills up with ink
and can no longer hold any more. When this occurs, the printer
indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing
the waste ink absorption pads is something an authorized canon service
facility can take care of for you.
SOURCE: Pixma MP780 has ''wrong cartridge'' fault.
ink tank
Testimonial: "Thank You. I purchased a new printhead and that fixed the problem. I needed to be sure of where the problem was before spending any money on the unit "
