Omron Portable Ecg Ekg Handheld Hcg 801 Monitor Logo
Posted on Jun 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can it show only 1 precordial leads? or it can show all precordial from v1 to v6 devices?
Paul Petry
Level 2:
Habit-Forming:
New Friend:
  • Expert 75 Answers
  • Posted on Jan 17, 2019
Paul Petry
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
75
Questions
0
Helped
24502
Points
228
If working it should show v1 to v6. Is the limb leads connected? it may need them for a "ground"
1helpful
I have a Bosch AL 3620 CV charger that has blown on plug-in. Is it repairable?
Hello, I was able to fix this charger via replacing several parts in the source part which were either short-circuited (transistors and diodes) or burnt (resistors):
F1 (fuse 2,5A)
R5 0,91R +-1%
V5 (ST)P6NK90Z
V1-V4 1N4007
V6 2N3904
V8 1N4148
R7, R8 300k +-2%
This won't help after 5 years, but maybe it can be helpful for someone else.
Error code 174
which engine,? v6?
Fuel TrimSystem Lean Bank 2
i have the factory manual. and car.
fuel trim (FSM) bank2 (right side) is 33% too high
that means its adding too much fuel , at a very lean bank 2.
it lists 8 reasons.
but can be distilled to, it is lean or the front right 0xy sensor is fibbing. (bad o2, or air leaks)
it shows 10 steps to find this, in 2 pages.
is P0175 present?
check for intake vacuum leaks and exhaust.
fuel pressure at spec?
all fuel injector tests bank 2
a weak MAF,or dirty. (bank 1 corrects but bank to fails)
ECT reading wrong.
O2 sensor front right.
it list fuel level (tank) as fibbing? not sure why?
FSM V1 pg 1a-90
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 OK SYNC" same as below
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 ...
www.faqqq.com/.../lg-aria-phone-showing-ldp-7016d-v1-4-scout-dx-v1...
Question Product: Phones Question Details: Lg aria phone showing "LDP-7016D V1.4SCOUT-DX V1.1 OK SYNC" same as below View Answers Search ...
LG Aria 130 & LDP-7016D Handset Issue - LG / Goldstar Systems ...
www.tek-tips.com/viewthread.cfm?qid=1694833
Oct 3, 2012 - I recently purchased 3 additional LDP-7016D handset for our phonesystem, but have ... System is a LG-Nortel Aria 130 running 7 handsets 1 x LDP-7024D Handset (V1.4) 6 x LDP-7016D Handsets (5 x V1.4 and 1 x V1.5)
1helpful
My Sony Cybershot DSC V1 viewfinder screen very briefly shows the taken image and this then quickly fades to a foggy whiteout which sometimes shows the ghost of the image taken. The same image shows when...
It is possible that the image sensor which is the CCD- charge coupled device is faulty and will need a replacement. However it is important that the OE part is required and so is best to take consensus with Sony spares and service.
Schiller AT-Plus, I cannot get all leads to print in sequence I avr v1 v4 II avl v2 v5 III avf v3 v6 not sure what a student did to change the...
The unit is apparently printing out in Cabarra sequence. To restore the correct lead sequence, do the following: Hit the ALT key followed by 7 then 1, hen the stop key. This will restore standard lead sequencing.
That is the start of the battle. If you desire a 3+1ryth format with a lead 2 at the bottom, which is our standard format, then you have more to do. For this format hit the ALT key followed by 1 then 0 followed by the stop key.to set the ryth lead to lead II at the bottom of the page, hit ALT followed by 3 then 8 then 2 followed by the stop key. If your filters are not enabled hit Alt 5 6 stop, alt 5 8 stop, Alt 8 3 stop, ALT 8 1 stop.Do a test print after all of this and be certain the unit is configured to your taste prior to a live patient.
It has "ra" at the bottom of the screen and is not
RA - Right Arm - This lead is the ground on a 12 lead ECG. If it is displayed then your RA leadwire is probably bad. To verify this as the problem, swap the leadwire between RA and V1 then hook it up to yourself or a simulator. If all the leads work (except for V1) then you know that you need to purchase a new lead wire. Also, Check your patches to ensure they are not dried up (if this is an intermittent problem).
1helpful
I have a new blackberry 9630 and a blue ant headset that i have previously paired to another blackberry. i cannot get my bb to find the headset when i search for devices.
I would delete all existing pairing profiles from your blackberry, once that is done do a hard reset by removing the battery from your phone while it is powered on. When it boots back up, reset the V1 by pressing the vol -/+ and MFB all at the exact same time. Ensure the buttons are NOT held simply clicked all at once like a mouse to a computer. When you get a consistent rapid flash the device has been reset and will go automatically into pair mode. Then re-search in your bluetooth menu, select the V1 when it shows up and enter the pin code 0000 if prompted.
Rylan
Cannot connec the Blueant V1 device to PC (tried 3
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
Sansa E250R doesn't recognize a 8GB card nor does my computer
Is you E280 V1 or V2? The V1 will only recognize up to 2GB. You can find this by going to settings, info. If the firmware number starts with 1 it's a V1. V2's start with 3.
If you have a V2 place the card in a card reader to format. Format card to FAT32. If not recognized by a card reader the card may be defective.
If the player is a V1 the micro SDHC can still be used by loading RockBox firmware. But note when running RockBox the sync port will be disabled. To use port the player can still be started in the Sansa firmware but a SDHC card will not be accessible.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Top Omron Medical Experts
Don A
Don A
ADMIN Andrew
ADMIN Andrew
Are you an Omron Medical Expert? Answer questions, earn points and help others
