Every time i print using my samsung scx-4623f it always paper jammed in exit area. though i always clear the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there
maybe a piece stuck in the fuser unit. If not open the back door and
check that there is a small black lever in the middle of the two
rollers sticking up as this is the sensor arm that determines that
there is a paper jam or not. If this is still there then the paper will
be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
