CAN I CHANGE THE PCB BOARD ON IWDC6105 INDESIT WASHER DRYER
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
SOURCE: My Indesit Washer dryer WIDL126 will not work all
My guess without seeing the machine is - The motor has gone / failed.
You could get someone to check the brushes on the motor, it's only a 30 minute job.
If the brushes are ok i.e more then 10mm long, I suspect the motor has burnt out if the machine is a number of years old.
Hope this helps
jb
SOURCE: hI WHEN I TURN ON MY MACHINE ALL THE LEDS KEEP
Hello, this usually is signaling that there is a problem in your machine. You will need to get a service technician in to diagnose the problem for you. I hope this is somewhat helpful.
SOURCE: washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Testimonial: "that worked a treat thanks"
SOURCE: indesit washer dryer stops halfway through a wash....
I have the same problem (ironing symbol and spin speed buttons flash). Anyone got the error codes list?
