Casio PATHFINDER ATOMIC SOLAR WATCH PAW1100-1V Logo
A
Anonymous Posted on Jun 24, 2014
How to set time casio paw 1100 1v - Casio PATHFINDER ATOMIC SOLAR WATCH PAW1100-1V
jamulder513
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Casio Expert 141 Answers
  • Posted on Mar 24, 2015
jamulder513
Casio Expert
Level 2:
Mentor:
New Friend:
Answers
141
Questions
0
Helped
85689
Points
435
On pages 2 and 3 of the manual (module 3043) you can find the instructions for automatic and manual time setting.
The manual can be downloaded here (direct download link):
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3043.pdf
1 Related Answer
Anonymous
  • Posted on Apr 29, 2009
SOURCE: my casio paw 500t is on pm mode during the day.
I contacted the manufacturer and they solved my issue.THANKS!
Paw-1200t
may be some dust inserted into the watch which prevents you to press the buttons .
another prob might be low battery. put your watch in sun in order to give some power to your solar battery
Casio paw 1500 does not work
ma need a new battery
Aug 26, 2013 • Watches
5helpful
Casio PAW-1200T Tough Solar Pathfinder watch says OPEN. Watch has never been opened, and solar battery has full charge. Nothing works but the basic time and the light.
so here is the fix if you get op en display on your casio pathfinder or whatever model. mine happens to be a paw 1200t
1. you gotta break it open 2 pins each side band comes off.
2. pry off the side pieces. this exposes 4 screws.
3. the base then comes off be careful of the gasket.
4. once inside. notice a round circular object on the base and a small oval shiny gold copper piece.
5. For whatever reason the shiny copper piece has shifted and does not make contact with the tiny little springs there are 2 if you shift the base to make contact with the gold piece the op en goes away and watch is back to normal.
6. the fix is move this little piece back to where it belongs. i got lucky and the glue still held when i firmly moved it to its original location. super glue came to mind if it wont stay where it belongs.
7. gasket orientation and cleaning out the gasket channel is a given i used welding tip cleaners to do the intricate work. under the bands are very grungy. mine is about 5-6 years old. reassemble the way it came out.
if your battery is good and you get this op en look to your display for whatever reason this worked for me and if casio uses this as a warranty or warning of water coming in your watch it was a STUPID DUMB IDEA. those springs should be solid state and the watch is useless until it is fixed no light, no baro, no alt, no comp. notta and no buttons work. there is no reason whatsoever that this shiny copper thing shifts but it happened to me and my watch is working and my battery has had H or full power since day one.
1helpful
PATHFINDER PAW 1300...HOW TO RESET? HAS THE WRONG TIME FOR CURRENT TIME ZONE...
Go to http://www.casio.com/support/ and you will see under "technical support" the link marked "manuals". You should be able to find all the information you need there.
Aug 14, 2010 • Watches
I need an instruction manual for a Casio Pathfinder watch. I show PAW-1400T-79VCR on the box as the number. Can u help me find one? It has a solar battery, digital compass, altimeter/barometer and...
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
I just bought my casio pathfinder paw 1100 wsatch and my alt and baro doesnt look like is working
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
How do I adjust a Casio PAW 1200 Titanium watch band.
You can get instructions from the Casio web site.
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
Feb 26, 2010 • Watches
My casio paw 500t is on pm mode during the day.
2answers
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
