Flanders 10055.011430: EZ Flow II - 14x30x1 Logo
A
Anonymous Posted on Jun 20, 2014
Is there an equivalent 3M filter to compare to the EZ Flow II? Lowe's sells the 3M filters. No one locally sells the EZ Flow II anymore.
Kevin Crompwell
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Jul 30, 2018
Kevin Crompwell
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
31103
Points
148
Keep an eye out on Craigslist and or eBay
Where will i get air filter foam/cloth
i am also looking for this answer, it looks like people try to make a quick buck on ebay selling this http://www.ebay.com/itm/NEW-PROJECTOR-AIR-FILTER-FOR-3M-Projector-FIT-FOR-3M-PROJEDTOR-AIR-FILTER-/180827230857?pt=US_Remote_Controls&hash=item2a1a249289
But im going to just go buy some thin foam type stuff and keep my old frame and glue or attach the new stuff to my old air filter frame and that should take care of it.
GOOD LUCK
1helpful
Spa on "flow"
Flow error code: Insufficient water flow through heater.
Common culprits:
Faulty flow sensor or pressure switch - switch stuck in open position, this is the most common cause of the Flow error code.
Dirty filter - try removing filter and run your system & see if the code returns.
Water line blockage - Check water lines & gate valves are clear/open.
If the problem is not listed above call a local spa technician as the problem could be something for significant.
Jan 17, 2012 • Pool & Spa
1helpful
I can not locate water filter on kenmore coldspot 5252210 side by side
That water filter fits into the grill/kickplate below the freezer door,this youtube video will show ya how to replace that filter http://www.youtube.com/watch?v=CPZgNYxFjjs
The part number for that filter is 9010 several places local will have it in stock included;
SEARS
HOMEDEPOT
LOWE'S
Your local appliance parts store
ACE HARDWARE
just bring in the old one to match it up
GENE
1helpful
The dehumidifier freezes up and continues to run so it never melts.
Check the air filter. Freeze ups are often caused by low airflow across the cold coil. A dirty air filter can severely restrict air flow. Replace or wash (if a washable type) the filter and allow the dehumidifier coils to defrost completely. Reinstall the filter and be sure to locate the appliance so that air flow in and out of it is not restricted in any way (not up against a wall, behind a door, curtains, etc.) and restart.
If the unit has been run without an air filter, the cooling coil fins are probably choked with dust and dirt. They should be cleaned with a product designed expressly for this purpose such as:
Evaporator coil cleaner is available from many hardware and "big box home supply stores" such as Lowe's or Home Depot.
Use only as directed, and buy filters! it's much easier to replace filters than cleaning coils.
I hope this helps and good luck! Please rate my reply "4 thumbs up" if it was helpful. Thanks!
Where is the water filter located in back?
On your refrigerator filter is in the ceiling of the refrig. section above the top shelf in the upper right corner
The part number for the filter is ukf8001 its available at your local appliance parts store,Sears,
Lowe's or HomeDepot. Just take in the old one to match it up.
Gene
How do I change the water filter? the light is red!
Whirlpool uses two different kinds of filters these videos will show you how to replace each different type.Filters are sold locally at Sear's Lowe's HomeDepot or your local appliance parts store.
http://www.youtube.com/watch?v=lTVfbVkEINI
Gene
How often should filters be replaced on a Heil Ultimate II gas furnace? Once at the beginning of the "heating" season and once at the end - would that be sufficient?
Hello, it depends what type of filters you are using, if you have the pleated filters such as the 3m brand they should be changed every three months If you are using the blue filters they should be changed every month.
I just purchased my 3M 16x25x1 air filter, i do not get what the filter should point to, toward the furnace or toward or toward the duct work
There is an arrow on the filter indicating the direction of air flow. The arrow should point toward the ductwork as that is the direction the air flows from the furnace fan.
Charlie
1helpful
I bought type a-c filters at walmart. they don't seem to fit right and the pool flow is slower. is there aanother type filter i can purchase?
I would buy the specific filter you need, not an "A slash C" designed to fit both. Various places online sell these and are about half priced compared to walmart. Check Amazon for a starter.
2helpful
How we can clean airfilter because message is appearing regarding clean your air filter
check in the menu to see if there is a filter timer that you can reset. if so, reset it. if not, there is an air flow sensor on the projector that will send that message if the air flow is decreased so the projector does not overheat. find the filter and remove it. blow it out with canned air and blow out the projector as well. replace the filter and enjoy!
Top Flanders Equestrian Experts
Imagdrider
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you a Flanders Equestrian Expert? Answer questions, earn points and help others
